2 6pin PCI-e connections on one cable?
Last response: in Systems
Homebuilt system Authority
Graphics card Master
What make and model of power supply do you have? From the sound of it, it may be under-powered for your new video card (what make/model is it as well)?
What model of Rosewill? If it is fairly new, it should already have 2 6-pin PCIe connectors.
Sounds like you want to use a molex to PCIe adapter cable. Is that correct?
Related ressources
I do have 2 pci-e connections on my PSU (factory connections, not adaptors) but they are running off the same cable, I was wondering if that was common to use for a graphics card or if it was too much power for one cable.
Ask the community
