Asus P4SD-VX POWER SUPPLY REPLACEMENT
i ORDERED A REPLACEMENT PS FOR MY SONY VAIO AND THE POWER CONNECTIONS ARE NOT THE SAME. i HAVE A 3 PIN CONNECTOR AND THE PS HAS A 4 PIN. ALL OTHER CONNECTORS APPEAR STANDARD. ????????????????????
KEN
3 answers Last reply
More about asus p4sd power supply replacement
  1. Sony!
  2. That is what you get when you buy Sony famous for proprietary stuff! If you can find out the voltages for your 3 pin you might be able to move the plug over. http://www.playtool.com/pages/psuconnectors/connectors.html
Power Supplies Asus Sony Vaio Components
