Toshiba monitor screen doesn't not turn on
Hello,
After a plane ride my toshiba monitor screen goes black. The monitor may sporadically turn on but then it would turn off again, and when I connect my computer to an external display screen, my laptop works perfectly. I can still see the display on the screen if I squint and it's very very dark. Is this a connection issue or a
screen problem? Thank you.
1 answer Last reply
More about toshiba monitor screen doesn turn
  1. The monitor cable may have come loose, or the backlight is going. Can you still see a very dim picture if you look closely, or is the backlight on and just showing you a blank screen?
PowerColor Connection Monitors Toshiba Graphics
