Hello, i got a plan on building a new computer with these parts
*Mobo : Gigabyte GA-970A-D3 or Gigabyte GA-990FXA-D3
Proc : AMD FX 8150 3.1 GHz or 3.6 GHz
*RAM : (any manufacturer) DDR3 8GB or 2x4 DDR3 or 2x8 DDR3
*Graphic : AMD Radeon HD6870 1GB
*SSD : (any manufacturer) 60GB
HD : 500GB or 1TB Seagate SATA
Dvd/cd : Sony 24x Sata Box
PSU : Gigabyte 550W or Cooler Master Gx 750W or Silent Pro Gold 700W
Casing : Cooler Master HAF 922
*)Need suggestions
with those options, is it compatible AND will it not reduce performance or something
Some people says for proc better go for phenom II, cause we already know the quality..but when you compare the prices, well..the differences is BIG right..
And for graphic, the other option is Geforce GTX 480, but some people opinion says better pick that HD 6870,
About SSD, i need guidance 'cause i'm not really sure about this.
The conclusion is, this is my plan, and i need experts to help in switching/changing/swapping parts with one above.
*)Price matters
*)Will put link for product if requested
*)Edit Reasons : Adding RAM options, price requirements for graphic
*)Need suggestions
*)Price matters
