Process called "System" Description - "NT Kernel & System"
  • CPUs
Last response: in CPUs
June 21, 2012 3:48:19 PM
Process called "System" Description - "NT Kernel & System". It is using nearly 92% of the CPUs. What is the problem of this ? I can't also kill the process. How to kill it.
More about : process called system description kernel system
a b à CPUs
June 21, 2012 4:51:19 PM
You can't; that's the OS in a nutshell.
m
l
June 21, 2012 4:54:13 PM
Thanks, now i found the problem that is because of IDT audio software in my Dell notebook.
m
l
a c 154 à CPUs
June 21, 2012 5:21:28 PM
You can only stop non important processes. The NT Kernal can't be stopped. If clicked on end process the computer will give you a BSOD and you'll have to restart the computer.
m
l
