Will this monster cooler fit into this case and mobo?
Last response: in Systems
March 6, 2012 8:18:42 PM
So I am building a computer in the next month. Just want to make sure all of my parts will fit well.
Specs so far
Asus Sabertooth X58 socket type 1366
G Skill Ripsaw 8gb
Intel Core I7 920 2.67 ghz
Corsair TX650 PSU
PNY Gefore GTS-450
Nividia Geforce GTS-450 just Nividia brand
M Audio Delta
Cooler Master V6
WD raptor drive 3.5
Seagate barracuda 500gb 3.5 drive
seagate barracuda 2.5 1 tb drive
Hitachi 160gb 2.5 drive
My case is a mid tower case. Will I be able to sli my two Gts-450s, As well as installing this godzilla! Cooler Master V6 on my Asus Sabertooth motherboard? Yes I like to use Dinosaur references I cant help myself!
Also does my build look solid?
case http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Mobo http://www.newegg.com/Product/Product.aspx?Item=N82E168...
March 6, 2012 8:31:10 PM
Why are you building this? Where do you live?
m
l
March 6, 2012 8:35:22 PM
What I mean is that all these parts are super old. Are you getting them second hand or something? It's not a good build unless there are some unknown constraints. Please share: desired monitor resolution, intended usage (gaming?), budget, and time frame.
m
l
March 6, 2012 8:35:54 PM
Yes, the motherboard will fit in the case just fine.
m
l
March 6, 2012 9:22:04 PM
I am switching my processor to a different motherboard and smaller case. I am salvaging parts from a 2 year build. On my current build I can play all games at max settings just fine. I dont see the point in getting a sandy bridge or new mobo just yet. Maybe in the next 2-3 years.
I can play games at 1920-1200 hdmi
I can play Mass effect 3 at max settings
I can play BF3 at high settings
I dont see a point in upgrading the mobo and processor just yet. My build can play any games that are out.
m
l
March 6, 2012 10:02:05 PM
Not worth it then, stick with your PC.
m
l
March 6, 2012 11:10:39 PM
Yeah, it wasn't clear if this was something you were planning to build or something you already had.
m
l
March 6, 2012 11:16:30 PM
Haha. True.
m
l
March 7, 2012 12:16:49 AM
my bad sorry for the bad info :(
m
l
March 7, 2012 12:19:23 AM
well base on its dimension it should fit well, i haven't tried that case yet but maybe i should check it out,
ahahaha and i was wondering when you said building i thought you were buying all of those and i was like get x79 >.< but then after some reading down here i see that you already have it, just like transfering stuff but still such an insane rig
m
l
March 7, 2012 12:49:15 AM
Don't worry about it rob, haha.
m
l
March 7, 2012 3:26:55 AM
one last question. I made my final decision and op for the liquid cooling system. I am going with the Intel BXRTS2011LC Liquid-cooled Thermal Solution For the LGA2011 Socket http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Will this fit in my case just fine? Kind of a noob question to ask but when I buy components I make sure everything needs to work right. Does it come with thermal solution or do I need to purchase more just be safe?
m
l
March 7, 2012 4:20:06 AM
It will fit. If you refer to the CM Storm Enforcer Owner's thread I posted, some people are using an H100 in that case, which has a radiator about twice as big as the Intel you've chosen.
m
l
March 7, 2012 10:30:46 AM
I agree, go with the H100. I'm using the H60 and it works well, and it has the same form as that Intel one. Any ways they are around the same price.
m
l
