Hello, I built a computer 3 years ago. I have an EVGA LGA 1366 X58 motherboard and 3 GB (3x1) of RAM. The RAM is DDR3 1333. Here is a link to it: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231222
I want to buy another 3GB of RAM for my desktop. I was looking and found two options; however, neither is 1333 with the same exact cas latency, voltages, and timings. Here are the two I found:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231224
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231229
I am wondering if either of these will work. If not, could you recommend something?
Thanks a lot!
Edit: Also, not to hijack my own thread, but I own a GTX 260 Core 216. Could you recommend a good upgrade for $300-400? Or, is it just worth waiting for something new to come out?
Thanks a lot!
