I just got done putting together my new PC, and it has a ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Motherboards+-+AMD-_-ASRock-_-13157176
There's the link if it helps. ^
The case is an Antec VSK-2450.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129089
I hooked everything up and turned it on. Everything runs, but everything towards the back of the case is unresponsive (USB ports, VGA, etc.)
Does anyone know what might have went wrong?
