Hello. I am planning to build my first computer.
Approximate Purchase Date: Mid-Late June
Budget Range: ~$500 After Rebates
System Usage from Most to Least Important:Gaming(med. to high. settings), Browsing the Internet, BOINC/F@H
Parts Not Required: HDD, DVD drive, mouse, keyboard, monitor, OS,
Preferred Website(s) for Parts:Newegg, Microcenter, NCIX(Any reputable site)
Country: USofA
Parts Preferences:by brand or type: None,(except Intel CPU) just make sure the brand is reputable and inexpensive.
Overclocking: Yes, but only on air.
SLI or Crossfire: No
Monitor Resolution: 1440x900
Additional Comments:Trying to go for best bang for my buck. I've made a spreadsheet of the parts I need. This is my 1st build, so I want to ask the TH community for some help. If you see something that needs changing, feel free to critique and add to it. My build is about ~$480 currently. The only things I can't decide betwwen are a PSU/mobo/heatsink. I don't currently have a heatsink(want to use stock one), but if there's a good one that fits withi n budget, please refer me to it. Also, MicroCenter offers $50 off any mobo purchased with an i5/i7, so take $50 the mobo price. And in addition, if I'm running at full load (with 1 HDD and 1 DVD drive, and a phone charging via US), will the PSU be enough, or is it overkill?
i5 2500K
http://www.microcenter.com/single_product_results.phtml?product_id=0354589
HIS AMD 6870 (Considering paying more for the XFX model)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161389
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
Corsair 4GB(2x2GB) Vengeance RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233141
Gigabyte Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233067
Gigabyte GA-Z68MA-D2H mobo
http://www.microcenter.com/single_product_results.phtml?product_id=0364087
APEX 500W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817154026
Country: USofA
i5 2500K
Gigabyte Case
APEX 500W PSU
