First of all i post this here because the mac page doesnt work for 3 days now...
Hi,
I'm trying to instal mac op my pc, like in this turtorial:
http://www.youtube.com/watch?v=nZhC1o82-HI
but i get this error half way the instalation:
Anyone can help me please? I cant use my computer now.. (on my laptop now)
Thanks in advance
Hi,
Mar 7 04:57:37 localhost Unknown[310]: Launching the Language Chooser for an OS Install
Mar 7 04:57:43 localhost LCA[311]: Bookmark failed to issue extension for item (depth=4000): No such file or directory
Mar 7 04:57:51 localhost LCA[311]: Launching the Installer using language code "English"
Mar 7 04:57:51 localhost OSInstaller[323]: Bookmark failed to issue extension for item (depth=4000): No such file or directory
Mar 7 04:57:51 localhost OSInstaller[323]: Mac OS X Installer application started
Mar 7 04:57:51 localhost OSInstaller[323]: 1 display(s) found.
Mar 7 04:57:51 localhost OSInstaller[323]: Display[1] is NOT using OpenGL acceleration.
Mar 7 04:57:51 localhost OSInstaller[323]: @(#)PROGRAM:Install PROJECT:Install-684
Mar 7 04:57:51 localhost OSInstaller[323]: @(#)PROGRAM:Mac OS X Installer PROJECT:OSInstaller-346.1
Mar 7 04:57:51 localhost OSInstaller[323]: Hardware: MacPro3,1 @ 3.07 GHz (x 8), 12288 MB RAM
Mar 7 04:57:51 localhost OSInstaller[323]: Running OS Build: Mac OS X 10.7 (11A511)
Mar 7 04:57:51 localhost OSInstaller[323]: Env: DYLD_NO_FIX_PREBINDING=1
Mar 7 04:57:51 localhost OSInstaller[323]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Mar 7 04:57:51 localhost OSInstaller[323]: Env: PWD=/
Mar 7 04:57:51 localhost OSInstaller[323]: Env: SHLVL=1
Mar 7 04:57:51 localhost OSInstaller[323]: Env: __OSINSTALL_ENVIRONMENT=1
Mar 7 04:57:51 localhost OSInstaller[323]: Env: CI_DEFAULT_OPENCL_USAGE=0
Mar 7 04:57:51 localhost OSInstaller[323]: Env: OS_INSTALL=1
Mar 7 04:57:51 localhost OSInstaller[323]: Env: _=/System/Installation/CDIS/LCA.app/Contents/MacOS/LCA
Mar 7 04:57:51 localhost OSInstaller[323]: No mutable product specified in NVRAM.
Mar 7 04:57:51 localhost OSInstaller[323]: Opening OSInstall package '/System/Installation/Packages/OSInstall.mpkg'.
Mar 7 04:57:51 localhost OSInstaller[323]: Using product <OSInstallRootProduct> at distance 5
Mar 7 04:57:53 localhost OSInstaller[323]: Memory statistics for 'Install Mac OS X' pane:
Mar 7 04:57:53 localhost OSInstaller[323]: Physical Memory Allocation: 549 MB wired, 8 MB trapped, 109 MB active, 85 MB inactive, 11537 MB free, 11731 MB usable, 12288 MB total
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x111742c30=disk0s2=Lion
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 04:57:53 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 04:57:53 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x111742c30=disk1s1=WINDOWS
Mar 7 04:57:54 localhost Unknown[312]: Keyboard Layouts: duplicate keyboard layout identifier -16899.
Mar 7 04:57:54 localhost Unknown[312]: Keyboard Layouts: keyboard layout identifier -16899 has been replaced with -28673.
Mar 7 04:57:54 localhost Unknown[312]: Keyboard Layouts: duplicate keyboard layout identifier -16900.
Mar 7 04:57:54 localhost Unknown[312]: Keyboard Layouts: keyboard layout identifier -16900 has been replaced with -28674.
Mar 7 04:58:11 localhost Unknown[312]: 2012-03-07 04:58:11.545 system_profiler[332:9203] Error loading /System/Library/SystemProfiler/SPFirewallReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fc46b41fcc0 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPFirewallReporter.spreporter, NSLocalizedDescription=The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:11 localhost Unknown[312]: 2012-03-07 04:58:11.612 system_profiler[332:9203] Error loading /System/Library/SystemProfiler/SPPrefPaneReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fc46b618e50 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPPrefPaneReporter.spreporter, NSLocalizedDescription=The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:11 localhost Unknown[312]: 2012-03-07 04:58:11.752 System Information[330:9a03] Error loading /System/Library/SystemProfiler/SPFirewallReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fcdb1455b60 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPFirewallReporter.spreporter, NSLocalizedDescription=The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:11 localhost Unknown[312]: 2012-03-07 04:58:11.760 System Information[330:9a03] Error loading /System/Library/SystemProfiler/SPPrefPaneReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fcdb3229240 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPPrefPaneReporter.spreporter, NSLocalizedDescription=The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:12 localhost Unknown[312]: 2012-03-07 04:58:12.166 system_profiler[333:9203] Error loading /System/Library/SystemProfiler/SPFirewallReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fd0a3900bf0 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPFirewallReporter.spreporter, NSLocalizedDescription=The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:12 localhost Unknown[312]: 2012-03-07 04:58:12.174 system_profiler[333:9203] Error loading /System/Library/SystemProfiler/SPPrefPaneReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7fd0a1c2dd20 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPPrefPaneReporter.spreporter, NSLocalizedDescription=The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:12 localhost Unknown[312]: 2012-03-07 04:58:12.267 system_profiler[334:9203] Error loading /System/Library/SystemProfiler/SPFirewallReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7f98a2419d30 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPFirewallReporter.spreporter, NSLocalizedDescription=The bundle “SPFirewallReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:12 localhost Unknown[312]: 2012-03-07 04:58:12.275 system_profiler[334:9203] Error loading /System/Library/SystemProfiler/SPPrefPaneReporter.spreporter: Error Domain=NSCocoaErrorDomain Code=4 "The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located." UserInfo=0x7f98a242fb10 {NSLocalizedFailureReason=The bundle’s executable couldn’t be located., NSLocalizedRecoverySuggestion=Try reinstalling the bundle., NSBundlePath=/System/Library/SystemProfiler/SPPrefPaneReporter.spreporter, NSLocalizedDescription=The bundle “SPPrefPaneReporter.spreporter” couldn’t be loaded because its executable couldn’t be located.}
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x11163cc30=disk0s2=Lion
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 04:58:23 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 04:58:23 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x11163cc30=disk1s1=WINDOWS
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x111742c30=disk0s2=Lion
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:36 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 04:58:36 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x7fce4621f428=disk0s2=Lion
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:47 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 04:58:47 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x111742c30=disk0s2=Lion
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 04:58:48 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 04:58:48 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 04:58:58 localhost Unknown[312]: 2012-03-07 04:58 Disk Utility[335] (CarbonCore.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1 - Client: coreservicesd, UID: 0, EUID: 0, GID: 0, EGID: 0
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1 - ODNodeCreateWithName request, SessionID: 00000000-0000-0000-0000-000000000000, Name: /Local/Default
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1 - loading configuration for '/Local' from '/System/Library/OpenDirectory/Configurations/Local.plist'
Mar 7 04:58:59 localhost opendirectoryd[100]: Loaded bundle at path '/System/Library/OpenDirectory/Modules/PlistFile.bundle'
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1 - unable to find authentication module 'ConfigurationProfiles'
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1 - unable to find service discovery callback for module 'PlistFile'
Mar 7 04:58:59 localhost opendirectoryd[100]: Registering for network changes
Mar 7 04:58:59 localhost opendirectoryd[100]: Registered subnode with name '/Local/Default'
Mar 7 04:58:59 localhost opendirectoryd[100]: failed to open local node for internal record copy
Mar 7 04:58:59 localhost opendirectoryd[100]: Registering for power changes
Mar 7 04:58:59 localhost opendirectoryd[100]: Registering for network power changes
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1, Node: /Local/Default - node assigned UUID - 83554110-EB71-451D-A682-029343CB0478
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.1, Node: /Local/Default - ODNodeCreateWithName completed
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.2 - Client: coreservicesd, UID: 0, EUID: 0, GID: 0, EGID: 0
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.2 - ODQueryCreateWithNode request, NodeID: 83554110-EB71-451D-A682-029343CB0478, RecordType(s): dsRecTypeNative:config, Attribute: dsAttrTypeStandard:RecordName, MatchType: EqualTo, Equality: CaseExact, Value(s): SharePoints, Requested Attributes: dsAttributesAll, Max Results: 1
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.2, Node: /Local/Default, Module: PlistFile - client is using a native record type 'config' which is not portable
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.2, Node: /Local/Default, Module: PlistFile - ODQueryCreateWithNode completed
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.3 - Client: coreservicesd, UID: 0, EUID: 0, GID: 0, EGID: 0
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.3 - ODNodeCreateRecord request, NodeID: 83554110-EB71-451D-A682-029343CB0478, RecordType: dsRecTypeNative:config, RecordName: SharePoints, Attributes: <none>
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.3, Node: /Local/Default, Module: PlistFile - client is using a native record type 'config' which is not portable
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.3, Node: /Local/Default, Module: PlistFile - ODNodeCreateRecord completed, delivered 1 result
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.4 - Client: coreservicesd, UID: 0, EUID: 0, GID: 0, EGID: 0
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.4 - ODQueryCreateWithNode request, NodeID: 83554110-EB71-451D-A682-029343CB0478, RecordType(s): dsRecTypeNative:config/SharePoints, Attribute: dsAttrTypeStandard:RecordName, MatchType: Any, Equality: CaseExact, Value(s): dsRecordsAll, Requested Attributes: dsAttrTypeNative:ftp_guestaccess,dsAttrTypeNative:smb_name,dsAttrTypeNative:sharepoint_account_uuid,dsAttrTypeNative:smb_createmask,dsAttrTypeNative:sharepoint_version,dsAttrTypeStandard:AppleMetaNodeLocation,dsAttrTypeNative:afp_guestaccess,dsAttrTypeNative:afp_shared,dsAttrTypeStandard:RecordType,dsAttrTypeNative:ftp_shared,dsAttrTypeNative:afp_name,dsAttrTypeNative:smb_oplocks,dsAttrTypeNative:afp_use_parent_owner,dsAttrTypeNative:smb_directorymask,dsAttrTypeStandard:RecordName,dsAttrTypeNative:afp_use_parent_privs,dsAttrTypeNative:smb_guestaccess,dsAttrTypeNative:smb_inherit_permissions,dsAttrTypeStandard:AppleMetaRecordName,dsAttrTypeNative:smb_shared,dsAttrTypeNative:directory_path,dsAttrTypeNative:smb_strictlocking,dsAttrTypeNative:sharepoint_group_id,dsAttrTypeNative:ftp_name, Max Results: 2147483647
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.4, Node: /Local/Default, Module: PlistFile - client is using an old record type 'dsRecTypeNative:config/SharePoints' should be using kODRecordTypeSharePoints
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.4, Node: /Local/Default, Module: PlistFile - flushing record '/private/var/db/dslocal/nodes/Default/config/SharePoints'
Mar 7 04:58:59 localhost opendirectoryd[100]: Module: PlistFile - ___index_record_block_invoke_1: sqlite3_prepare_v2: 21
Mar 7 04:58:59 localhost opendirectoryd[100]: 290.4, Node: /Local/Default, Module: PlistFile - ODQueryCreateWithNode completed
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/Bookmark.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/Contact.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/Font.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/Mail.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/Movie.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/QuartzComposer.qlgenerator
Mar 7 04:59:42 localhost Unknown[312]: 2012-03-07 04:59:42.541 Disk Utility[335:14b07] [QL] Can't get plugin bundle info at /System/Library/Frameworks/QuickLook.framework/PlugIns/iCal.qlgenerator
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x11163cc30=disk0s2=Lion
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 05:00:14 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 05:00:14 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x11163cc30=disk1s1=WINDOWS
Mar 7 05:00:26 localhost OSInstaller[323]: Allowing machine sleep.
Mar 7 05:00:33 localhost OSInstaller[323]: Preventing machine sleep.
Mar 7 05:00:33 localhost OSInstaller[323]: InstallerStatusNotifications plugin loaded
Mar 7 05:00:34 localhost OSInstaller[323]: ================================================================================
Mar 7 05:00:34 localhost OSInstaller[323]: Choices selected for installation:
Mar 7 05:00:34 localhost OSInstaller[323]: Install: "Mac OS X"
Mar 7 05:00:34 localhost OSInstaller[323]: BaseSystemBinaries.pkg : com.apple.pkg.BaseSystemBinaries : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: BaseSystemResources.pkg : com.apple.pkg.BaseSystemResources : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: OSInstall.mpkg : com.apple.mpkg.OSInstall : 10.7.0
Mar 7 05:00:34 localhost OSInstaller[323]: Essentials.pkg : com.apple.pkg.Essentials : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: BootCamp.pkg : com.apple.pkg.BootCamp : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: BSD.pkg : com.apple.pkg.BSD : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: PodcastCapture.pkg : com.apple.pkg.PodcastCapture : 1.0.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: JavaTools.pkg : com.apple.pkg.JavaTools : 1.0.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: RemoteDesktop.pkg : com.apple.pkg.RemoteDesktop : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: SIUResources.pkg : com.apple.pkg.SIUResources : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: AdditionalEssentials.pkg : com.apple.pkg.AdditionalEssentials : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: AdditionalSpeechVoices.pkg : com.apple.pkg.AdditionalSpeechVoices : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: AsianLanguagesSupport.pkg : com.apple.pkg.AsianLanguagesSupport : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: MediaFiles.pkg : com.apple.pkg.MediaFiles : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: MigrationAssistant.pkg : com.apple.pkg.MigrationAssistant : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Mail.pkg : com.apple.pkg.Mail : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: AddressBook.pkg : com.apple.pkg.AddressBook : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: iCal.pkg : com.apple.pkg.iCal : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Automator.pkg : com.apple.pkg.Automator : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: DVDPlayer.pkg : com.apple.pkg.DVDPlayer : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: iTunes.pkg : com.apple.pkg.iTunes : 8.2.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: iChat.pkg : com.apple.pkg.iChat : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: JavaEssentials.pkg : com.apple.pkg.JavaEssentials : 1.0.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Safari.pkg : com.apple.pkg.Safari : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: OxfordDictionaries.pkg : com.apple.pkg.OxfordDictionaries : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Japanese.pkg : com.apple.MacOSX.lang.ja : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: German.pkg : com.apple.MacOSX.lang.de : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: French.pkg : com.apple.MacOSX.lang.fr : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Spanish.pkg : com.apple.MacOSX.lang.es : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Italian.pkg : com.apple.MacOSX.lang.it : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Dutch.pkg : com.apple.MacOSX.lang.nl : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Danish.pkg : com.apple.MacOSX.lang.da : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Finnish.pkg : com.apple.MacOSX.lang.fi : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Korean.pkg : com.apple.MacOSX.lang.ko : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Norwegian.pkg : com.apple.MacOSX.lang.no : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Russian.pkg : com.apple.MacOSX.lang.ru : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Swedish.pkg : com.apple.MacOSX.lang.sv : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: BrazilianPortuguese.pkg : com.apple.MacOSX.lang.pt : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: SimplifiedChinese.pkg : com.apple.MacOSX.lang.zh_CN : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: TraditionalChinese.pkg : com.apple.MacOSX.lang.zh_TW : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Portuguese.pkg : com.apple.MacOSX.lang.pt_PT : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Polish.pkg : com.apple.MacOSX.lang.pl : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Arabic.pkg : com.apple.MacOSX.lang.ar : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Hungarian.pkg : com.apple.MacOSX.lang.hu : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Turkish.pkg : com.apple.MacOSX.lang.tr : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: Czech.pkg : com.apple.MacOSX.lang.cs : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: X11User.pkg : com.apple.pkg.X11User : 10.7.0.1.1.1309412550
Mar 7 05:00:34 localhost OSInstaller[323]: OSInstall.pkg : com.apple.pkg.OSInstall : 10.7.0.1
Mar 7 05:00:34 localhost OSInstaller[323]: It took 0.00 seconds to summarize the package selections.
Mar 7 05:00:34 localhost OSInstaller[323]: Memory statistics for 'Installing' pane:
Mar 7 05:00:34 localhost OSInstaller[323]: Physical Memory Allocation: 503 MB wired, 12 MB trapped, 102 MB active, 90 MB inactive, 11581 MB free, 11773 MB usable, 12288 MB total
Mar 7 05:00:34 localhost OSInstaller[323]: Remote Install Assistant found at 1024null)
Mar 7 05:00:34 localhost OSInstaller[323]: No recovery image found relative to distribution
Mar 7 05:00:34 localhost OSInstaller[323]: Set authorization level to root for session
Mar 7 05:00:34 localhost runner[329]: Administrator authorization granted.
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/BaseSystemBinaries.pkg (582659072 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/BaseSystemResources.pkg (278027264 b)
Mar 7 05:00:34 localhost OSInstaller[323]: IF will install package file://localhost/System/Installation/Packages/OSInstall.mpkg (0 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Essentials.pkg (2010667008 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/BootCamp.pkg (6598656 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/BSD.pkg (564994048 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/PodcastCapture.pkg (14619648 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/JavaTools.pkg (27096064 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/RemoteDesktop.pkg (67584 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/SIUResources.pkg (67584 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/AdditionalEssentials.pkg (37835776 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/AdditionalSpeechVoices.pkg (293474304 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/AsianLanguagesSupport.pkg (60019712 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/MediaFiles.pkg (52092928 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/MigrationAssistant.pkg (27924480 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Mail.pkg (45618176 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/AddressBook.pkg (12897280 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/iCal.pkg (32684032 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Automator.pkg (24425472 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/DVDPlayer.pkg (21167104 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/iTunes.pkg (105423872 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/iChat.pkg (29308928 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/JavaEssentials.pkg (21808128 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Safari.pkg (32510976 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/OxfordDictionaries.pkg (102232064 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Japanese.pkg (47386624 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/German.pkg (47719424 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/French.pkg (47799296 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Spanish.pkg (46760960 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Italian.pkg (45203456 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Dutch.pkg (45266944 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Danish.pkg (42574848 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Finnish.pkg (42875904 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Korean.pkg (45684736 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Norwegian.pkg (42617856 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Russian.pkg (45253632 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Swedish.pkg (42807296 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/BrazilianPortuguese.pkg (43142144 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/SimplifiedChinese.pkg (45471744 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/TraditionalChinese.pkg (44797952 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Portuguese.pkg (43168768 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Polish.pkg (43360256 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Arabic.pkg (42934272 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Hungarian.pkg (30493696 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Turkish.pkg (30557184 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/Czech.pkg (30099456 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/X11User.pkg (82910208 b)
Mar 7 05:00:34 localhost OSInstaller[323]: PK will install package file://localhost/System/Installation/Packages/OSInstall.pkg (0 b)
Mar 7 05:00:34 localhost OSInstaller[323]: Total install size including padding: 6436848640 b + 0 b non-OS collection items
Mar 7 05:00:34 localhost OSInstaller[323]: PFPackage:ackageWithURL - can't instantiate package: /System/Installation/Packages/OSInstall.mpkg
Mar 7 05:00:34 localhost OSInstaller[323]: Error opening package "OSInstall.mpkg".
Mar 7 05:00:34 localhost OSInstaller[323]: Starting installation:
Mar 7 05:00:34 localhost OSInstaller[323]: Performing volume consistency check on 'Lion'.
Mar 7 05:00:34 localhost OSInstaller[323]: Checking Volume
Mar 7 05:00:34 localhost OSInstaller[323]: Checking file system
Mar 7 05:00:34 localhost OSInstaller[323]: Checking Journaled HFS Plus volume.
Mar 7 05:00:34 localhost OSInstaller[323]: Checking extents overflow file.
Mar 7 05:00:34 localhost OSInstaller[323]: Checking catalog file.
Mar 7 05:00:35 localhost OSInstaller[323]: Checking multi-linked files.
Mar 7 05:00:35 localhost OSInstaller[323]: Checking catalog hierarchy.
Mar 7 05:00:35 localhost OSInstaller[323]: Checking extended attributes file.
Mar 7 05:00:36 localhost OSInstaller[323]: Checking volume bitmap.
Mar 7 05:00:36 localhost OSInstaller[323]: Checking volume information.
Mar 7 05:00:36 localhost diskmanagementd[327]: DM ->T-[DMToolBootPreference buildBootCachesForDisk:forcing:]: inDiskUDS=0x7fce46202008=disk0s2=Lion inForce=1
Mar 7 05:00:36 localhost OSInstaller[323]: The volume Lion appears to be OK.
Mar 7 05:00:36 localhost OSInstaller[323]: Volume repair complete.
Mar 7 05:00:36 localhost OSInstaller[323]: Updating boot support partitions for the volume as required.
Mar 7 05:00:36 localhost diskmanagementd[327]: DM <-T-[DMToolBootPreference buildBootCachesForDisk:forcing:]: 1
Mar 7 05:00:36 localhost OSInstaller[323]: Volume passed consistency checks.
Mar 7 05:00:36 localhost OSInstaller[323]: Calculating expected install size requirements
Mar 7 05:00:36 localhost OSInstaller[323]: Reserved for install: 6436.8 MB (0.0 MB non-OS collection items, 0.0 MB recovery system)
Mar 7 05:00:36 localhost OSInstaller[323]: Currently available: 119468.4 MB
Mar 7 05:00:36 localhost Unknown[312]: 2012-03-07 05:00:36.682 Mac OS X Installer[323:17857] Looking for system packages
Mar 7 05:00:36 localhost Unknown[312]: 2012-03-07 05:00:36.690 Mac OS X Installer[323:17857] no system packages found
Mar 7 05:00:36 localhost Unknown[312]: 2012-03-07 05:00:36.690 Mac OS X Installer[323:17857] No or Invalid system receipts found on /Volumes/Lion/Recovered Items
Mar 7 05:00:36 localhost Unknown[312]: 2012-03-07 05:00:36.690 Mac OS X Installer[323:17857] Attempting fallback using: /System/Library/PrivateFrameworks/SystemMigration.framework/Resources/FallbackSystemFiles.plist
Mar 7 05:00:36 localhost Unknown[312]: 2012-03-07 05:00:36.865 Mac OS X Installer[323:17857] Finding system files...
Mar 7 05:00:37 localhost Unknown[312]: 2012-03-07 05:00:37.082 Mac OS X Installer[323:17857] Writing system path cache.
Mar 7 05:00:37 localhost Unknown[312]: 2012-03-07 05:00:37.085 Mac OS X Installer[323:17857] FSF cache NOT written: /Volumes/Lion/Recovered Items/Library/Caches/com.apple.FindSystemFiles.plist
Mar 7 05:00:37 localhost OSInstaller[323]: Reapable space: 0.0 MB
Mar 7 05:00:37 localhost OSInstaller[323]: Configuring volume "Lion"
Mar 7 05:00:37 localhost OSInstaller[323]: Preparing disk for Netbooted OS Install.
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ->T+[DMToolBootPreference getPartitionBootability:]: inUDS=0x1117c5c30=disk0s2=Lion
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootable=1 (bootable right now without any further action)
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootCapable=0 (bootable if you call MKCFPrepareBootDevice)
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMBootSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMFSSurgeryRequired=0 (for primitive MBR on BIOS, add boot block and loader)
Mar 7 05:00:37 localhost diskmanagementd[327]: DM ..T+[DMToolBootPreference getPartitionBootability:]: PMNewfsRequired=0 (bootable with MKCFPrep but it will rudely carve)
Mar 7 05:00:37 localhost diskmanagementd[327]: DM <-T+[DMToolBootPreference getPartitionBootability:]: MKerr=0 out=4=0x4
Mar 7 05:00:37 localhost OSInstaller[323]: Volume disk0s2 mounted at /Volumes/Lion is ready
Mar 7 05:00:37 localhost OSInstaller[323]: Preparing disk for local booted OS Install.
Mar 7 05:00:37 localhost OSInstaller[323]: Physical memory statistics immediately before turning on virtual memory backing store:
Mar 7 05:00:37 localhost OSInstaller[323]: Physical Memory Allocation: 888 MB wired, 9 MB trapped, 108 MB active, 91 MB inactive, 11192 MB free, 11391 MB usable, 12288 MB total
Mar 7 05:00:37 localhost OSInstaller[323]: Activated virtual memory backing store at mount point '/Volumes/Lion'
Mar 7 05:00:37 localhost OSInstaller[323]: Preparing disk for local booted install.
Mar 7 05:00:37 localhost OSInstaller[323]: Creating installation log on volume "Lion"
Mar 7 05:00:37 localhost OSInstaller[323]: Create temporary directory "/Volumes/Lion/Install.323KWHfuH"
Mar 7 05:00:37 localhost OSInstaller[323]: IFPKInstallElement (47 packages)
Mar 7 05:00:37 localhost OSInstaller[323]: Using authorization level of root for IFPKInstallElement
Mar 7 05:00:37 localhost OSInstaller[323]: Can not connect to /var/run/systemkeychaincheck.socket: No such file or directory
Mar 7 05:00:37 localhost OSInstaller[323]: PackageKit: ----- Begin install -----
Mar 7 05:00:37 localhost OSInstaller[323]: PackageKit: request=PKInstallRequest <47 packages, destination=/Volumes/Lion>
Mar 7 05:00:37 localhost OSInstaller[323]: PackageKit: packages=(
"PKLeopardPackage <file://localhost/System/Installation/Packages/BaseSystemBinaries.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/BaseSystemResources.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/Essentials.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/BootCamp.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/BSD.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/PodcastCapture.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/JavaTools.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/RemoteDesktop.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/SIUResources.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/AdditionalEssentials.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/AdditionalSpeechVoices.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/AsianLanguagesSupport.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/MediaFiles.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/MigrationAssistant.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/Mail.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/AddressBook.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/iCal.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/Automator.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/DVDPlayer.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/iTunes.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/iChat.pkg>",
"PKLeopardPackage <file://localhost/System/Installation/Packages/JavaEssentials.pkg>",
Mar 7 05:00:37 localhost OSInstaller[323]: PackageKit: Extracting file://localhost/System/Installation/Packages/BaseSystemBinaries.pkg (destination=/Volumes/Lion/.OSInstallSandbox-tmp/Root, uid=0)
Mar 7 05:01:02 localhost OSInstaller[323]: PackageKit: Using / as external payload root for package com.apple.pkg.BaseSystemResources
Mar 7 05:01:02 localhost OSInstaller[323]: PackageKit: Extracting file://localhost/System/Installation/Packages/BaseSystemResources.pkg (destination=/Volumes/Lion/.OSInstallSandbox-tmp/Root, uid=0)
Mar 7 05:01:44 localhost OSInstaller[323]: PackageKit: Extracting file://localhost/System/Installation/Packages/Essentials.pkg (destination=/Volumes/Lion/.OSInstallSandbox-tmp/Root, uid=0)
Mar 7 05:03:03 localhost OSInstaller[323]: PackageKit: Got copier error 2 extracting to path ./System/Library/PrivateFrameworks/ServerKit.framework/Versions/A/Resources/XSXsanAdmin.icns: Read-only file system
Mar 7 05:03:03 localhost Unknown[312]: /SourceCache/AppleFSCompression/AppleFSCompression-37/Common/DataPool.c:135: Error: finished pool without filling it
Mar 7 05:03:03 localhost Unknown[312]: /SourceCache/AppleFSCompression/AppleFSCompression-37/Common/commonUtils.c:360: Error: fh_pread -1
Mar 7 05:03:03 localhost Unknown[312]: /SourceCache/AppleFSCompression/AppleFSCompression-37/Common/StreamCompressor.c:294: Error: pread failed for /Volumes/Lion/.OSInstallSandbox-tmp/Root//System/Library/PrivateFrameworks/ServerKit.framework/Versions/A/Resources/XSXsanAdmin.icns: Invalid argument
Mar 7 05:03:03 localhost Unknown[312]: /SourceCache/AppleFSCompression/AppleFSCompression-37/Common/StreamCompressor.c:928: Error: returning errno 22 from FinishStreamCompressorQueue
Mar 7 05:03:07 localhost OSInstaller[323]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=110 "An error occurred while extracting files from the package “Essentials.pkg”." UserInfo=0x7fa556ce4010 {NSLocalizedDescription=An error occurred while extracting files from the package “Essentials.pkg”., NSFilePath=/Volumes/Lion/.OSInstallSandbox-tmp/Root, NSURL=Essentials.pkg -- file://localhost/System/Installation/Packages/OSInstall.mpkg, PKInstallPackageIdentifier=com.apple.pkg.Essentials, NSUnderlyingError=0x7fa556f75310 "The operation couldn’t be completed. FinishStreamCompressorQueue error"} {
NSFilePath = "/Volumes/Lion/.OSInstallSandbox-tmp/Root";
NSLocalizedDescription = "An error occurred while extracting files from the package \U201cEssentials.pkg\U201d.";
NSURL = "Essentials.pkg -- file://localhost/System/Installation/Packages/OSInstall.mpkg";
NSUnderlyingError = "Error Domain=BOMCopierFatalError Code=1 \"The operation couldn\U2019t be completed. FinishStreamCompressorQueue error\" UserInfo=0x7fa556ca37a0 {NSLocalizedFailureReason=FinishStreamCompressorQueue error, offset=2847022, type=BOMCopierFatalError, sourcePath=/System/Installation/Packages/Essentials.pkg, destinationPath=/Volumes/Lion/.OSInstallSandbox-tmp/Root}";
PKInstallPackageIdentifier = "com.apple.pkg.Essentials";
Mar 7 05:03:07 localhost OSInstaller[323]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=110 "An error occurred while extracting files from the package “Essentials.pkg”." UserInfo=0x7fa556ce4010 {NSLocalizedDescription=An error occurred while extracting files from the package “Essentials.pkg”., NSFilePath=/Volumes/Lion/.OSInstallSandbox-tmp/Root, NSURL=Essentials.pkg -- file://localhost/System/Installation/Packages/OSInstall.mpkg, PKInstallPackageIdentifier=com.apple.pkg.Essentials, NSUnderlyingError=0x7fa556f75310 "The operation couldn’t be completed. FinishStreamCompressorQueue error"}
Mar 7 05:03:08 localhost OSInstaller[323]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Mar 7 05:03:09 localhost OSInstaller[323]: No system on disk Lion to revert bless
Mar 7 05:03:09 localhost OSInstaller[323]: Unable to revert bless to target or imgsrc.
Mar 7 05:03:09 localhost OSInstaller[323]: Allowing machine sleep.
Mar 7 05:03:09 localhost OSInstaller[323]: Memory statistics for 'Install Failed' pane:
Mar 7 05:03:09 localhost OSInstaller[323]: Physical Memory Allocation: 543 MB wired, 15 MB trapped, 266 MB active, 99 MB inactive, 11365 MB free, 11730 MB usable, 12288 MB total
Mar 7 05:03:16 localhost Unknown[312]: 2012-03-07 05:03 Mac OS X Installer[323] (CarbonCore.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 7 05:03:16 localhost opendirectoryd[100]: 290.5 - Client: coreservicesd, UID: 0, EUID: 0, GID: 0, EGID: 0
Mar 7 05:03:16 localhost opendirectoryd[100]: 290.5 - ODQueryCreateWithNode request, NodeID: 83554110-EB71-451D-A682-029343CB0478, RecordType(s): dsRecTypeNative:config/SharePoints, Attribute: dsAttrTypeStandard:RecordName, MatchType: Any, Equality: CaseExact, Value(s): dsRecordsAll, Requested Attributes: dsAttrTypeNative:ftp_guestaccess,dsAttrTypeNative:smb_name,dsAttrTypeNative:sharepoint_account_uuid,dsAttrTypeNative:smb_createmask,dsAttrTypeNative:sharepoint_version,dsAttrTypeStandard:AppleMetaNodeLocation,dsAttrTypeNative:afp_guestaccess,dsAttrTypeNative:afp_shared,dsAttrTypeStandard:RecordType,dsAttrTypeNative:ftp_shared,dsAttrTypeNative:afp_name,dsAttrTypeNative:smb_oplocks,dsAttrTypeNative:afp_use_parent_owner,dsAttrTypeNative:smb_directorymask,dsAttrTypeStandard:RecordName,dsAttrTypeNative:afp_use_parent_privs,dsAttrTypeNative:smb_guestaccess,dsAttrTypeNative:smb_inherit_permissions,dsAttrTypeStandard:AppleMetaRecordName,dsAttrTypeNative:smb_shared,dsAttrTypeNative:directory_path,dsAttrTypeNative:smb_strictlocking,dsAttrTypeNative:sharepoint_group_id,dsAttrTypeNative:ftp_name, Max Results: 2147483647
Mar 7 05:03:16 localhost opendirectoryd[100]: 290.5, Node: /Local/Default, Module: PlistFile - client is using an old record type 'dsRecTypeNative:config/SharePoints' should be using kODRecordTypeSharePoints
Mar 7 05:03:16 localhost opendirectoryd[100]: 290.5, Node: /Local/Default, Module: PlistFile - ODQueryCreateWithNode completed
Thanks in advance
