P parbar Honorable Jun 22, 2012 1 0 10,510 Jun 22, 2012 #1 Hello, Will most pre-built desktops fit in a new case like a corsair 400r example with HP P7-1110 fit or a Inspiron 620?
Uther39 Distinguished Feb 3, 2011 2,778 0 21,160 Jun 22, 2012 #2 parbar : Hello, Will most pre-built desktops fit in a new case like a corsair 400r example with HP P7-1110 fit or a Inspiron 620? Yes they will, but some of the mobo to case wiring will take some tracing from the old case so you no what cable goes where. Upvote 0 Downvote
B bluekoala Distinguished Feb 8, 2008 333 0 18,810 Jan 12, 2014 #3 HP front USB plugs are non standard, you will not be able to use the front US in most cases. Otherwise the rest should be fine. Upvote 0 Downvote
