Noobie- Idle and Load temps safe?
Last response: in CPUs
Related ressources:
- ForumIdle Chit Chat...
- Forum2500k Idle/Load Temps : Should I OC?
- ForumE6600@3.6Ghz, Core 54 Idle , 60 Load . 1.625 Vcore, am I safe ? Or am I r
- ForumGTX 570 Twin frozr Idle and Load temps ?
- ForumSafe OC idle operating temps for AMD Athlon X2 4400+
- ForumI7 930 idle/load temps 43/72
- ForumI7 930 high idle low temps on load .
- ForumAre these idle CPU temps safe enough to start Prime95?
- ForumE8600 Idle and Load Temps .
- ForumI7 920 safe load temps
- ForumE6600 Core 2 Duo expected temps at Idle or load ?
- ForumE6600 OC Temps : Idle/Load delta slightly exceeds recommended
- ForumIs 55C a safe temp for AMD FX 4100 under load ?
- ForumSafe idle temp
- ForumHas ASUS Auto Tune given me a safe OC?
- ForumPSU Help
- Forum[Solved] I5 3570k temps/repaste
- Forum[Solved] Safe temp for i7 2600k
- Forum2500k temps extremely high.
- ForumI7 3770k stock heatsink (40C idle 95C Maxed) temperature concerns
- More resources
98C is the max core temp and 72C is the max recommended CPU temp, so as long as you stay in the low 70's or less, and you're golden.
