So I have ordered these parts are they compatible?
Last response: in Systems
Just a last check in case I need to cancel anything.
Case
Coolermaster HAF 912+ £65
Mobo
Intel socket 1155 Mobo (ASRock Pro3 Gen3) B3 Rev. £113
CPU
Intel i5 2500k Sandy Bridge Socket 1155 £160
RAM
G.Skill Ripjaw 2x4Gb 1600mhz DDR3 Ram £35
PSU
Corsair 850w Enthusiast series £94
OS
Windows 7 Full version £100
HDD
500Gb Western Digital Caviar Black £59
Optical Drive
Sony 24x DVDRW (just a cheap drive) £13
I am going to use an old GPU Radeon HD 4650 for now but will buy
GPU
Asus Gforce 560ti @900Mhz
Is all this compatible? Will it all fit in that case? and I chose my 850w PSU because I will probably run 2 560ti in the future.
Thanks
Related ressources
ramish said:
Ok!! it Looks Perfect
By the way!
Instead using intel plz use amd! its better and cheaper!
huh? how did you say use amd! its better and cheaper lol :non:
its rubbish not better.
lol, don't feed the trolls X. Nice looking system Joe, you will be pleased. Your psu should also be good if you decide to add another 560ti. Everything will fit now, sli may be a little tight.
Ask the community
