Help me build my dream PC
Hello,
I am building my dream PC. These are the components I chose. Please let me know what you think about them because it's the first time I build a PC. Also, do you think that I will be able to use the Intel Water Cooling in the LIAN LI Case I selected and will the motherboard work/fit in that case?
Thank you very much!
LIAN LI PC-B10 USB3.0 Black Aluminum ATX Mid Tower Computer Case
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
COOLER MASTER Silent Pro Gold Series RSA00-80GAD3-US 1000W ATX 12V v2.3 / EPS 12V v2.92 SLI
Logitech Cordless Desktop EX 100 Black USB RF Wireless Standard Keyboard and Mouse
G.SKILL Ares Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3960X Extreme Edition Sandy Bridge-E 3.3GHz (3.9GHz Turbo) LGA 2011 130W Six-Core
Intel BXRTS2011LC Liquid-cooled Thermal Solution For the LGA2011 Socket
Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) with Transfer
3 Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB
7 answers Last reply
More about help build dream
  1. hello
    your build is not balanced
    you have a mid range 560 card with a extreme series 6 core
    you don't need a 1k psu for a 560 unless you want to have multi gpu setup in the future
    for a liquid cooler I would recommend a h100 if you have dual exhaust fans on top or the h80 for a single radiator
    32gigs sounds like an overkill, get 16 gigs unless you will be running virtual mashines
  2. Thank you very much..I will be using this computer to make music so I do need a lot of RAM and a powerful processor. The graphic card is not that important because I will just play a few games. The power supply needs to be silent but I'll look at other options.
    Any other help would be greatly appreciated :)
  3. chop that $1000 processor just a little to the 3930K, which will pay for a 7970 gpu.
  4. can you give us a budget?
  5. ^+1 for asking budget.remember-
    in price/performance value
    SB>SB E
    X79 is made for servers and heavily multi threaded apps that can use 4+ cores.this is dead end.you can't upgrade in future.hardly 10%~15% boost over SB in games and double the cost :(
    say no to x79 for gaming.
    Z68 is better.infat it's hell better.reasons-
    cheaper
    best price to performance ratio
    can upgrade to ivy bridge
    all the necessary features an enthusiast requires!
    so there's no point of spending $1k on cpu and getting a $250 gpu LOLOLOLO!!!!!!
  6. Thanks for the answers and btw unlimited budget (well 8k is the maximum)..
    I am looking to build a computer to use software such as Cubase to make music so the videocard is not important to me. I am not planning on using this machine for games...
    Hellfire, as I said..I need the most powerful machine out there (I'm not interested in dual Xeons machines though).
  7. I suggest an Intel Xeon E5-2650 Sandy Bridge-EP 8 core. This will require overclocking.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819117266
    Seems ASUS has no 2011 motherboards to support Xeon so the ASROCK Extreme6.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157290
    The rest is up to you but I would suggest 2 x 7970's.
New Build Systems Product
