Hi everyone, I'm planning on building my first computer and would like to keep it in the $400-$500 range. The most I would use it for is playing Sims 3 and surfing the Internet. I was wondering if this combo would work well enough to play the game at high settings if I add a video card, and if so, could someone recommend one? (I don't need it to be a top of the line one, but I also don't really want to play with the integrated video card.)
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.753182
Also, are all these parts compatible? I'm totally new to this so I just want to make sure everything will work perfectly! I would assume Newegg wouldn't put something together that wouldn't work, but just wanted to be sure! Thanks in advance for your help!
EDIT: Here's a quick look at the requirements for reference
2.4 GHz P4 processor or equivalent
1.5 GB RAM
128 MB Video Card with support for Pixel Shader 2.0
Microsoft Windows Vista Service Pack 1
At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games
For computers using built-in graphics chipsets under Windows, the game requires at least:
Intel Integrated Chipset, GMA 3-Series or above
2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
0.5 GB additional RAM
1.5 GB RAM
