Approximate Purchase Date: June, July 2012
Budget Range:max max 5000 Before After Rebates
System Usage from Most to Least Important: gaming, surfing the internet
Parts Not Required: All new parts want 2 pc's one for me, my old one for wife
Preferred Website(s) for Parts: ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
CORSAIR DOMINATOR GT 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 Desktop Memory Model CMT16GX3M4X2133C9
EVGA 03G-P3-1595-AR GeForce GTX 580 (Fermi) Classified ULTRA 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
OCZ Agility 3 AGT3-25SAT3-240G 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) x2
Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model BC-12B1ST/BLK/B/AS - OEM
COOLER MASTER Silent Pro Gold Series RSA00-80GAD3-US 1000W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Still planing on the U2-UFO case from mountain mods just so i never have to buy one again
http://www.mountainmods.com/CYO_picker.php not sure if this will take you to what i was looking at. $469.99 -Total for the case setup
This looks close to what i had posted on the 9th but I made a few changes. I wanted the motherboard for the upgrade options and I'm not sure if i can use an i5 processor so i went with the i7 that is listed, this way i can jump to Ivy bridge when it comes out. I do have a question about the i7 that's listed if I plan to oc would it be better to not get the turbo boost. Planing on raid 0 the ssd'd, the GPU I was thinking just the one till kepler comes out then sli if its worth it. With everything listed this should be about 3100. is this all compatible and would i have to upgrade any major parts sooner than i thought.
Country: USA
Parts Preferences: by brand or type: I would like to use an intel CPU & asus mobo with a 24"+ LCD and full tower case.
Overclocking: Yes
SLI or Crossfire: Yes, in the future
Monitor Resolution: 1920x1200
Additional Comments: Needs to be upgradable
