Hi,
I am new to this forum and not at all an expert when it comes to custom computer builds.
I would like to ask for your expert advice on a new (affordable) render-machine for the office. We are mac based where we currently are running parallels in combination with rhino4/vray for modelling and rendering. This set-up is not ideal as you know as the render-times are redicoulously slow..
I have been looking at these specs:
option1:
http://www.ebay.de/itm/HTPC-Multimedia-PC-Intel-Core-i7-2600-USB3-GT520-1TB-4GB-ASUS-Computer-/180741917995?pt=DE_Technik_Computer_Peripherieger%C3%A4te_PC_Systeme&hash=item2a150ecd2b
option2:
http://www.ebay.de/itm/HTPC-Multimedia-PC-Intel-Core-i5-2400-USB3-GT520-1TB-4GB-ASUS-Computer-/180741912350?pt=DE_Technik_Computer_Peripherieger%C3%A4te_PC_Systeme&hash=item2a150eb71e
option3:
http://www.ebay.de/itm/Gamer-PC-Computer-AMD-Phenom-II-X6-1075T-8GB-ATI-HD-6670-1GB-ASUS-Kingston-/180730675550?pt=DE_Technik_Computer_Peripherieger%C3%A4te_PC_Systeme&hash=item2a1463415e
on all the above i am thinking (after reading some on forums..) that i need to upgrade the mainboard to the auus p8h67?
is this important or can i stick with the default?
graphics card is ok?
upgrade to 16gb ram
do i need a stronger ventilation set-up?
on option 3 the setup with the phenom x6 is perhaps also a question: is this is your minds a good solution for my user purpose? or is the i7 the best way to go?
all the above is from ebay here in germany, we would prefer getting the system from this country for tax & return reasons, but if you know any better place for getting the perfect setup for a similar price (900euro max i would say...) also then please let us know
thank you for any help on this!
best,
carl
option1:
option2:
option3:
upgrade to 16gb ram
best,
carl
