RAM & Power Supply for LGA 2011
Hello,
I want to buy the specifications below. Can you suggest a good 8 GB RAW & Power Supply for me. please ?!
- Asus Rampage IV Extreme
- NVIDIA GeForce GTX 570
- Intel Core i7-3820
Best Regards,
Q8Xbox
10 answers Last reply
More about power supply 2011
  1. Ok, let see is this a good & compatible PC spec:
    - Corsair 16 GB (4 x 4 GB) DDR3 2133 MHz (PC3 17000)
    - eXtreme Power Plus 550W
    - Cooler Master X6 CPU Cooler
    - WD Caviar Black 2TB
    I have two questions:
    1-Is it necessary to buy CPU Cooler or not...?!
    2- Is there any suggestion spec to reduce the total price without changing The Motherboard, CPU & HHD...?!
    Best Regards,
    Q8Xbox
  2. You shouldn't need a CPU cooler just because it comes with a stock fan but if you plan on running your CPU under heavy load I would consider it.
  3. uh, why would u buy sb-e cpu if you ain't gonna sli? the only 'benefit' you get from 3820 over 2600k is extra pci-e lanes which are only useful if you gonna do 3/4-way sli/crossfire, and quad channel ram which has pretty questionable uses (i assume this is a gaming rig since you picked up gtx570)
    note that i put 'benefit' under quotation marks because sb-e chip doesn't include hd graphics, hence no quick sync which is amazing for video encoding
    let's not forget the limited overclocking options on 3820 (dealing with not too flexible bins; getting over 4,3ghz is luck based)
    anyways, what i'm trying to say is that you're much better off with 2500k/2600k; cpu costs less, motherboard costs less, and you can use that cash u save on a better gpu
    edit: oh and if you plan on buying such a high end pc, don't even think about using stock cooler, or atleast don't tell anyone you are
    here's what i'd change to get alot more for the money:
    1) cpu - i7 2600k
    2) mobo - asrock z68 gen3 extreme4 (extreme3 is ~40-50$ cheaper and lacks 3rd pci-e slot, 3rd and 4th usb3.0 ports and 3rd and 4th sata3 ports which are only beneficial to ssd drives, so quite useless if you won't have more than 2 ssds)
    3) gpu - radeon 7870 (same price as gtx570, performs better, draws less power; benchmarks: http://www.tomshardware.com/reviews/radeon-hd-7870-review-benchmark,3148.html) or better (r7970 if you want/can afford), since you'll have spare money going down from x79 platform to z68
    4) psu - 650w corsair/xfx/antec (i don't know much about the brand you picked); ~750-800w if you plan on doing sli/crossfire later on
    5) ram - 1600/1866mhz is enough really, corsair is good choice (g.skill/mushkin are viable alternatives)
    6) storage - get an 120/128gb ssd and a couple of 1tb wdc black drives - more drives = bigger lung capacity if you get what i'm saying (less bottlenecking on data transfering)
    7) cpu cooler - a) coolermaster hyper 212 evo -best bang for your buck; b) noctua nh-d14 - best performance air cooler on the market (at double the price)
    1) cpu - i7 2600k
    if its only for gaming, i'd change the i7 to an i5 2500k
  5. ^ hyper threading comes in handy if you fraps/stream and 2600k will probably outlast 2500k by atleast a year
    besides op seems to be sitting on quite a hefty budget since he planned on chucking out $450 on just a motherboard
  6. he hasn't mentioned that he's going to record at all, and $100 seems like a lot of money for an upgrade that won't make that much of a difference unless he does
    Best Regards,
    Q8Xbox
    mobo is highly overpriced and has unnecessary features.instead of LGA2011 with a slower gpu it's better to get 1155 with 7970.
    8gb is more than enough for gaming as well as multi tasking.
    psu is complete crap.xfx 550w is a way better choice.
    better option as you are building a new rig,close this thread and make another one in systems section.
    tell me your max budget and fill this-
    http://www.tomshardware.com/forum/261222-31-build-advice
  8. Thanks guys for the advice. I appreciate your help...
    Ok, how about this spec:
    - Asus P8 Z68-V Pro
    - Intel i7-2600k
    - Corsair Vengeance Blu 8 GB (2X4 GB)
    - WD HHD 2TB
    - Corsair Professional Series 650-Watt 80 Plus Certified
    Best Regards,
    Q8Xbox
  9. looks alot better when it comes to price/performance ratio
    you should consider getting an ssd to go along with the hdd if you can afford, it's ridiculous how much more responsive your system is with it
    - Asus P8 Z68-V Pro
    - Intel i7-2600k
    - WD HHD 2TB
    Best Regards,
    Q8Xbox
    wise choice.2500k>2600k for gaming.
    wait for 7870.it's newer,cooler,less power hungry and faster than a gtx 570.
New Build Power Supplies RAM Systems
