Sorry, I should have been more thorough...
OK, Budget, as inexpensive as I can go without sacrificing my needs, intel only, no amd's. I need several USB2 ports, 2 front, 4-6 back for my preexisting peripherals. I have no idea about this MoBo or if it has what I need to match the case, and the case works well with it. The case has good cooling (*lots of fans), and seems to be roomy by measurement. I am trying to educate myself to be knowledgeable on my parts. But sadly some of this tech stuff is so over my head I worry I will match the parts wrong. I have someone who has offered to assemble for a flat fee, but I want to know if this is good before I show it to them (*no trust issues, I just want to know myself, what I am buying). Forewarned, forearmed, knowledge is power...etc!
I do 2D/3D graphics using CS5, Painter 11, PP2012, 3dsMax, Vue9, and lots of other mid sized programs. I plan to also buy Z-Brush soon.
Thank you so very much!
Ariana
New Build
Case
Item #:N82E16811147153
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm
Model #:CHALLENGER
Return Policy:Standard Return Policy
In Stock
$59.99 -$5.00 Instant $54.99
MoBo
Item #:N82E16813131707
ASUS P8P67-M PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Model #
8P67-M PRO (REV3.0)
In Stock
Mail in Rebate Card13-131-707
$149.99
GPU
Item #:N82E16814130625
EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Model #:01G-P3-1556-KR
Return Policy:VGA Standard Return Policy
In Stock
Mail in Rebate Card14-130-625
$144.99 -$15.00 Instant $129.99
PSU
Item #:N82E16817139025
CORSAIR Gaming Series GS800 800W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC High Performance Power ...
Model #:CMPSU-800G
In Stock
Mail in Rebate Card17-139-025
$139.99 -$15.00 Instant $124.99
i5 2500k
Item #:N82E16819115072
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
Model #:BX80623I52500K
Return Policy:Iron Egg Replacement-Only Return Policy
In Stock
$224.99
Ram
Item #:N82E16820233143
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
Model #:CMZ16GX3M4A1600C9
Return Policy:Memory Standard Return Policy
In Stock
$94.99 -$5.00 Instant $89.99
Optical Drive
Item #:N82E16827118031
SONY Black SATA DVD-ROM Drive Model DDU1681S-0B - OEM
Model #
DU1681S-0B
In Stock
$19.99
OEM
Item #:N82E16832116992
Microsoft Windows 7 Professional SP1 64-bit - OEM
Model #:FQC-04649
Return Policy:Software Standard Return Policy
In Stock
Extras added on...
Thermaltake BlacX N0028USU External Hard Drive SATA Enclosure Docking Station 2.5" & 3.5" USB 2.0
Model #:N0028USU
Item #:N82E16817153066
In Stock
$34.99 -$5.00 Instant $29.99
