Need SMPS for running 2 GTX 550 Ti in SLI.
Hello everyone.
I will be running
2 GTX 550 Ti
in near future. So what I want to know is which SMPS and how many watts of SMPS will be able to run my pc stabily?
My Config.
Intel Core 2 Duo
E4600 @ 2.4 Ghz (Sood Upgrading to Core i7 Processor)
Intel DG31PR (Motherboard) (Sood Upgrading)
2 X 1 GB DDR2 RAM (I'll be upgrading it to 16 GB with my Motherboard)
3 X 320 GB WD HDD
6 answers Last reply
More about need smps running
  1. For a system using two GeForce GTX 550 Ti graphics cards in 2-way SLI mode NVIDIA specifies a minimum of a 500 Watt or greater power supply that has a combined +12 Volt continuous current rating of 38 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors.
  2. Get a 650W smps to be on the safer side...
    If you are planning to do a lot of gaming and not high end video editing, then i would suggest you to go for an i5 2500K and pair it with a good Z68 mobo.
  3. Specify which brand and model smps should I in for?
  4. Specify which brand and model smps should I in for?
  5. Specify which brand and model smps should I in for?
    What brands and models do you have available to you in your market?
    Do you have an online retailer that you usually purchase from?
    What is your SMPS budget range?
Power Supplies Gtx Components
