Hello,
I had built a system with the following config several months ago (thx to rwpritchett and need4speeds for their inputs):
ASUS MOBO http://www.newegg.com/Product/Product.aspx?Item=N82E16813131659
Athlon Regor dual core processor
Samsung 2 TB HDD
Blu ray burner
2*2GB memory
Case http://www.frys.com/product/6145869 (link: http://www.silentpcreview.com/forums/viewtopic.php?t=57965 has more info.)
My computer stopped starting (meaning nothing shows up on TV). However, was busy over the past several months and never got back to it. Last weekend, I finally re-installed Windows 64-bit and now it starts. However, I have multiple problems:
1) Sometimes, it doesn't start - nothing on screen problem happens occasionally. What I do is turn it off, then press the power button again and it works.
2) I saw a thermal shutdown couple of times - I resolved this by taking off the top case (so there is more air flow). But, I was really surprised in finding this issue (my stand is an enclosed unit - but has a large opening in the back). I have bought a USB fan (not yet delivered) to help with this - is this expected? For this machine, I assumed heat wouldn't be a problem. THe issue it seems is that the blu ray player sits almost on top of the CPU, and the heat doesn't have any place to escape on the MB. I also installed a probe which tells me the temp. of the process and MB. I see the processor go up to 65 C and MB to 65C. At what point should I get worried (because I would really like to put the case back in). How can I solve this problem - don't know if the USB fan will help at all. I had thought the system would run rather cool. Do I also need to buy something like this (http://www.newegg.com/Product/Product.aspx?Item=N82E16835106145)? My case doesn't really do heat dissipation well...
3) the WIFI just doesn't work. Resetting it doesn't help. Seems to be a driver problem, don't know how to resolve it. I put a WIFI USB adapter to help get over it now.
4) If I "sleep" my machine (put it on standby), I am not able to get it back up using my keyboard or by pressing the power button. The only way is to press the power button for 3 seconds for it to turn off and then turn it on. How can I make it go to sleep and get back up in a few seconds (is there some bios setting).
5) I installed XBMC as the media center with several addons/plugins and it works fine. Having the sleep on XBMC working as in #4 woudl be great.
6) The remote doesn't do anything beyond basic tasks like arrow keys. How can I configure the remote to accept other commands - today I use a wireless KB to get around it. It would be great if my harmony remote can be used as a one stop.
Thanks a lot for your patience....
Samsung 2 TB HDD
Blu ray burner
2*2GB memory
