Dell Latitude HDD problem: "Bad or missing loader-system halted."
Hello,
Can anyone please advise possible ways to fix this problem, so that I can retrieve data, before replacing the HDD.
Thanks, Brian.
1 answer Last reply
More about dell latitude problem missing loader system halted
  1. check if your hard drive is seen in the bios
    if it is make sure its the 1st bootable device and that you havent left a cd/dvd in the optical drive
    if it still wont boot use another pc to get a copy of something like ubuntu live--you can run it without
    installing it from a disc or usb drive
    as long as your hard drive is actually spinning you can then copy the data off
Latitude Hard Drives Dell Components
