T TeodoI7 Distinguished Feb 21, 2011 157 0 18,690 Jan 6, 2012 #1 So im buying a new I5 2500K computer but do not know what graphics card is the best the ones i have to choose from is EVGA GTX 560 (non Ti) XFX HD 6870 So which is the best i will mostly play BF3 at 1920x1080 if thats any help thanks in advance
Solution T T That_Guy88 Jan 6, 2012 Those two generally have about the same performance with the 6870 having a slight edge. The 6870 can be had for $150, even less after rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E16814161389 the 560 is closer to the 180-200 range
T That_Guy88 Distinguished Dec 31, 2011 76 0 18,660 Jan 6, 2012 Solution #2 Those two generally have about the same performance with the 6870 having a slight edge. The 6870 can be had for $150, even less after rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E16814161389 the 560 is closer to the 180-200 range Upvote 0 Downvote Solution
T TeodoI7 Distinguished Feb 21, 2011 157 0 18,690 Jan 6, 2012 #3 Best answer selected by TeodoI7. Upvote 0 Downvote
