How do i connect my graphics card to my power supply ?
Hello, I just baught a saphire radeon HD 6770 graphics card and also a ASROCK n68c-s and im wondering how to plug the 6 pin thing that goes into the graphics card into the power supply there was an awful diagram so I really have no clue please help !
13 answers Last reply
More about connect graphics card power supply
  1. What is your model power supply? Does it have a six pin PCI-e connector?
    Does it have enough power to run the card is what Im also concerned about.
  2. What make/model of power supply do you have?
  3. Do I need to actually go into the power supply to see if it has a 6 pin PCI-e connector ? and I really have no clue about the model of the power supply
    Bestec
    Model : ATX0180P5WB
    I think that's it
  5. That looks like a 180w power supply. It will not power the 6770, if that is correct.
  6. Yes, you need to check whether your PSU has it.
    Check this photo, it's my system:
    http://img860.imageshack.us/img860/3246/dscf4754h.jpg
    The lower circle shows when cables come out of my PSU.
    The upper one shows where you have to plug in the 6 pin connection.
    You don't have to hide the cables like I did, just connect the 6 pin connector from your PSU to your Graphics card.
    That's how my GTX 560 Ti looks after I connected it, please note, my card requires 2 connectors, while yours will require one (probably):
    http://img685.imageshack.us/img685/4194/dsc01693u.jpg
    So do I need a new psu because it's too low watts and I can't see any 6pin connectors that will go into the graphics card ??
  8. What's your whole system setup? I think we all might need to know this before we recommend the next PSU. And yes, you need a new PSU at least.
    However, something like http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034&Tpk=earthwatts%20430 would be a good PSU choice if you plan to stick with the 6770.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035 if you want a little more power...
  9. I'd go with http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027, it's a bit cheaper, and is as good quality as antec!
    Just please, don't buy some random cheap power supply, because it might cook your system..
    ^agreed, however your linked model has a pretty terrible rating :P.
  11. IDK what rating there shows, but I am using it myself (just 600W model) and it hasn't disappointed me. Plus, Corsair is a good and quality brand.
  12. LOL yes your PSU wattage is to small, get something like a 500w from a good manufacturer.
  13. Great I just turned on my pc with the new motherboard as rock n68c-s and I've just got a very loud fan and also my monitor doesn't seem to want to work with it connects to the pc and then goes to sleep any help ??
Radeon Power Supplies Graphics Cards Connection Graphics
