Hello all,
I have a problem with my graphics card not sending a signal to my VGA monitor.
What's weird is that this is ONLY occurs when I try sending this to a VGA input monitor/TV, yet works with HDMI/DVI displays.
The card I'm using is this XFX 9600 GSO:
http://xfxforce.com/en-us/Products/Graphics-Cards/NVIDIA/NVIDIA-GeForce-9-Series/NVIDIA-GeForce-9600-GSO.aspx
This card has 2 outputs, one DVI and one HDMI. It works fine when I am using the setups as follows:
HDMI to HDMI (single HDMI/HDMI cable)
DVI to HDMI (single DVI/HDMI cable)
DVI to DVI (single DVI/DVI cable)
but not DVI to VGA... (using a single DVI to VGA cable, as well as a VGA to VGA cable w/ DVI/VGA converter)
The 4 displays I've tested it on are:
19" LCD Monitor --> VGA input ONLY (does not work) ***TRYING to use this one for this computer.
22" LCD Monitor --> VGA + DVI input (DVI works, VGA doesn't)
22" LED HDTV ---> VGA + HDMI input (HDMI works, VGA doesn't)
32" LCD HDTV --> VGA + HDMI input (HDMI works, VGA doesn't)
If anyone can help me understand what's going on or help fix the issue, It would be very much appreciated.
Thanks alot.
Thanks alot.
