Hey guys! I'm having one heck of a problem, and could really use some help. I have 2 displays running on my PC, and sometimes I like to disable the second display so I can plug my TV into my computer for games, etc. I could do this just fine with my previous graphics card (Radeon HD 5750), but I recently upgraded to an MSI Twin Frozr II HD 6950 2GB. For some reason, if I try to disable my second display, it just BSODs on me. If I try to just "clone" my display, it does the same thing too. It also BSODs when I try to uninstall the drivers. I've tried unplugging it while my PC was in use, and, yep you guessed it, BSOD. If I unplug it before it boots, It runs fine...until you move ANYTHING over to where the second display was, then it just BSODs. I CAN change the resolution and orientation of it though without a BSOD(I can run graphically intense programs on it fine too). I've looked everywhere on Google for a solution, but none could be found. Any suggestions? My system as a whole functions perfectly besides this little problem(no performance drops, fragmenting, etc. although there are weird green pixel patterns right before it BSODs) Here are my current PC specs:
OS: Windows 7 64 bit Home Premium
CPU: AMD Phenom II X4 955 @3.2Ghz (stock clocks)
Graphics Card: MSI Twin Frozr II Radeon HD 6950 2GB
RAM: 8GB of DDR3 RAM
Motherboard: ASUS M4A88TD-V EVO/USB3
My first display is 1920X1080 and my second display is 1600X900. The BSOD is always IRQL_NOT_LESS_OR_EQUAL. I have the most up to date drivers installed for this card. Any suggestions? Thanks for any help you guys offer me.
