Solved
Is the power supply enough?
Hello, I was wondering if the power supply in the following list is enough to support the entire build. The power supply is bundled in the case.
http://pcpartpicker.com/p/aHjm
2 answers Last reply Best Answer
More about power supply enough
  1. Best answer
    the vast majority of PSU that come with cases are junk. since you are not using a dedicated video card, that PSU will work but I would personally go with something like an antec 350w for a simple desktop build.
  2. Best answer selected by pizza5647.
Power Supplies Support Build Components
