Need suggestions on cooling fan and heat sink upgrade
Hello,
Currently I am running AMD Phenom(TM) II X4 965 Black Edition, with Asus M4A78LT-M LE AM3 mobo. (I believe I need 120 mm fan?)
The CPU temperatures are going way above 62 degree which AMD suggested max temp.
What new CPU fan and heat sink would you guys recommend? The default ones are awful. Also tried using different thermal paste, but the effect is minor.
ps. the current CPU temp is 75 degree on full load. 50 on idle
4 answers Last reply
More about need suggestions cooling heat sink upgrade
  1. Depending upon your case size, the Cooler Master Hyper 212 Evo - very popular found here
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    or even the more expensive (and a bit better) Cooler Master TPC 812 here
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
    Again, you need a rather wide case (7"+) to fit those...
    There are also low profile types if those are too large.
  2. ahhh, its CoolerMaster Elite 310 Mid Tower Gaming Case
    Dimension
    (W) 191 x (H) 437 x (D) 468 mm
    (W) 7.5 x (H) 17.2 x (D) 18.4 inch
    Which would be great O.o?
    ps. does UK have newegg xD
  3. Thank you very much! I'm going for your suggestion, hope this will solve everything :)
Fan CPUs Components Product
