I built the following system:Here is a build; although it might be overkill.
http://www.newegg.com/Product/Prod [...] 6827106289
http://www.newegg.com/Product/Prod [...] 6811112154
http://www.newegg.com/Product/Prod [...] 6822148840
http://www.newegg.com/Product/Prod [...] 6817139027
http://www.newegg.com/Product/Prod [...] 6820233202
http://www.newegg.com/Product/Prod [...] 6813131716
http://www.newegg.com/Product/Prod [...] 6819115076
To cut cost you could downgrade the cpu to an i3 (Maybe even a G620) and shave around $80+ off the price.
About $587
But the power supply doesn't work. It doesnt have a 12V 4 prong to plug into the motherboard. Can I get a recommendation for a replacement power supply that will work with the above components?
Brian
About $587
Brian
