CPU Type: Intel Core i7-2670QM @ 2.20GHz
CPU Speed: 2195.7 MHz
Cache size: 256KB
O/S: Windows 7 (64-bit)
Total RAM: 6054.7 MB.
Available RAM: 4236.5 MB.
Video settings: 1366x768x32
Video driver:
DESCRIPTION: Intel(R) HD Graphics Family
MANUFACTURER: Intel Corporation
plus it also has a geforce gt 540m 1gb, and uses nvidia optimus to determine what card to use.
On normal settings my 3D score on passmark is only 580, and when setting my system to "high performance" it ranks just barely over 600. The average for my gpu is 720, and when searching most users are well over 700 with the 540m.
Also after running the 3d test I get: "The directx 10 test ran correctly however there was an error during the cleanup phase and some objects may not have been released. This should not have affected the test score."
I updated my nvidia drivers. What else can I try? Does my card have a problem? Maybe my mobo? I thought passmark could be using the intel hd card and not the 540m but its scoring too high for that to be the case. Also my 2D solid vectors and transparent vectors are god awful ...
HELP please and thank you!
CPU - Integer Math: 2154.6
CPU - Floating Point Math: 2496.5
CPU - Find Prime Numbers: 1022.7
CPU - SSE: 33.6
CPU - Compression: 8881.0
CPU - Encryption: 25.4
CPU - Physics: 389.9
CPU - String Sorting: 4936.7
Graphics 2D - Solid Vectors: 1.8
Graphics 2D - Transparent Vectors: 1.8
Graphics 2D - Complex Vectors: 128.3
Graphics 2D - Fonts and Text: 188.3
Graphics 2D - Windows Interface: 98.3
Graphics 2D - Image Filters: 359.0
Graphics 2D - Image Rendering: 591.4
Graphics 3D - Simple: 399.5
Graphics 3D - Medium: 208.1
Graphics 3D - Complex: 69.0
Graphics 3D - DirectX 10: 10.6
Memory - Allocate Small Block: 5375.9
Memory - Read Cached: 2375.2
Memory - Read Uncached: 2218.4
Memory - Write: 2173.5
Memory - Large RAM: 3133.5
Disk - Sequential Read: 89.9
Disk - Sequential Write: 86.3
Disk - Random Seek + RW: 5.0
CPU Mark: 7358.7
2D Graphics Mark: 396.7
Memory Mark: 1519.6
Disk Mark: 655.4
3D Graphics Mark: 603.9
PassMark Rating: 1696.0
System information: This Computer
CPU Manufacturer: GenuineIntel
Number of CPU: 1
Cores per CPU: 4
Cache size: 256KB
Video driver:
BIOS: Intel Video BIOS
DATE: 1-27-2011
Drive Letter: C
Total Disk Space: 186.3 GBytes
Cluster Size: 4.0 KBytes
File system: NTFS
Cache size: 256KB
Video driver:
CPU - SSE: 33.6
CPU Mark: 7358.7
Memory Mark: 1519.6
Disk Mark: 655.4
Number of CPU: 1
Cores per CPU: 4
Cache size: 256KB
Video driver:
DATE: 1-27-2011
Drive Letter: C
File system: NTFS
