Solved
Water cooling vs. Air cooling
I would like to know the pros and cons of both, and a good water cooling and air cooling unit. I am willing to spend 100$ - 120$ on the unit, and if it is a Corsair, I would like to know a good replacement fan for it. (The fans that it comes with are loud I think.)
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
Thanks in advance
EDIT: Whats the chance that the water cooling unit will fail, and break in my computer?
3 answers Last reply Best Answer
More about water cooling cooling
  1. Best answer
    Closed loop liquid coolers aren't worth it. You can get just as good performance from an air cooler. What cpu are you using because something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 will probably do.
    Proper water cooling is more of a hobby than anything. With your case you'd either have to take out your 3.5" bays or put a 200mm up top but i don't know if you'd have enough space.
    Could I overclock with that fan?
    I am going to use the i5 2500k CPU
  3. Best answer selected by MrFlyingbananas.
Homebuilt Water Cooling Cooling Systems
