Closed Solved
Problem with hd 5570 OEM
Hi guys,
I have bought an hp pavilion p6760br, here the spec:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c02718810&jumpid=reg_R1002_USEN
And i having BSODs all the time, blue screen viewer said it's because of these .sys files (atikmapg.sys, dxgkrnl.sys and dxgmms1.sys),
but it only happens with video drivers installed (driver by hp, original catalyst by amd and driver by microsoft), and if i unnistall the driver and run driver sweeper after, it runs perfect, but i can't game.
I'm using windows 7 Ultimate SP1 64-bit
P.S.:MSI Kombustor crash, but i can benchmark perfectly the unigine tropics.
P.SS: When i run a game my screen stay black, but i can play and listen the game but with no image, and if i try crtl+alt+del or alt+tab it crash in BSOD.
Edit: I have tried to run this card in other system and works perfectly, but with windows 7 Enterprize SP1 32-bit, the other system is an DELL optiplex GX620
11 answers Last reply Best Answer
More about problem 5570
  1. It really sounds like a bad card, I would explore warranty.
  2. I don't tinhk the video card is problem, as I said the card works fine on other systems.
    There are a chance that could be the motherboard?
  3. It could be motherboard, CPU, memory, PSU, Hard Drive. Anything.
  4. memory isn't I runed memtest, windows memory diagnostics and the diagnostics that have in bios, HD is from my older system and is ok, psu too (is a corsair tx950w), cpu appears ok too my only suspect is the motherboard
    In any case the system should still be under warranty, next likely culprit would be the motherboard.
  6. UPDATE!!
    I have tested now my hd 5570 on my old system and works fine, and i returned my XFX 6800 XTreme to my pc and works fine too,
    soo that appears to be an incompatibility :o
  7. kakaofull said:
    UPDATE!!
    And the card came pre installed in the HP?
    Yes.
    I know it's too crazy to understand :pt1cable:
  9. Best answer
    kakaofull said:
    Yes.
    Still a warranty issue! Why buy HP and treat it like a homebuild? You have gone through a lot of work to proof that you got a faulty product! I personally would RMA the whole thing to them!
  10. ok i will try it. thanks
  11. Best answer selected by kakaofull.
Radeon Graphics
