Need help, PC not booting since upgrade?
Hi
Not sure where to ask so asked in a couple of threads.
I just replaced my M2N32, 64fx-62 and Corsair 4GB with a P8Z68, i7 and Corsair 16GB.
My hard drives are HD401LJ and HD501LJ Sata drives. The GPU is a 7950GX-2.
I thought I wired up everything but when I hit power the fans spin but that's it. No Bios, it doesn't even sound like the drives are spinning.
Any ideas?
8 answers Last reply
More about need help booting upgrade
  1. bruvvamoff said:
    Hi
    Any ideas?
    What's your OS? If it's windows 7 try installing your non system hard drive and the GPU one at a time (rebooting in between). Thats remove. Reboot. Install the HDD. Reboot. Install the Gpu. Reboot. See what happens.
  2. Pull the CMOS battery
    I'm on Windows XP Pro 64bit.
    CMOS battery being what and where?
    It looks like a big watch battery. On your board it should be near "ASUS" between your PCI slot and your PCI-x16 slot.
    Pulled it out, put it back, rebooted. Got nothing. Removed my GPU and used the i7 graphics and I got somewhere. Different issue now. Got the BIOS set up page, save and continue, windows screen momentarily, then bios screen momentarily, then windows failed to load screen.
    Same thing happens over and over, won't even boot in safe mode.
  7. You have to reload Windows with such a huge change in hardware.
    I would agree. When you do, install each part one at a time like I posted earlier. Start with 8gb's of ram also (once its running you can add the rest). If your able, go with windows 7 x64 instead. Hope this helps you. :)
Homebuilt Corsair Systems
