Case cooling
Last response: in Systems
Hi All
This is my second post.I recently built up my first gaming computer.
Specs:am3+motherboard
4gb ram
amd phenomII x4 945 @3.00 ghz
gtx550ti
generic 450w psu
and a normal cheapest computer store case.
Ok so my problem:my gtx 550ti(stock overclocked to normal 970mhz) reaches 75degrees when playing cod 4.I am worried,is that ok for that card?My case has 5 fans:1 in front,2 top,1 bottom,1 back.The front one is blows cool air in case,Back is exhaust.Now the bottom one is just below motherboard and harddrives.Currently it is in exhaust.The 2 top ones blow cool air in the case.
Thanks all answers are appreciated. :bounce:
More about : case cooling
Ah... close!
Top and bottom = Intake
Rear and two top = Exhaust
You are probably bringing in cool from the front, then immediately sending it out the bottom exhaust fan. Probably the same thing with the top / rear fans. ....the airflow isn't going from front-to-back across your components. Make the change above and let the forum know if you still have temp issues.
Related ressources
xXZeboXx said:
Ok thanks I will swop the top two around.BTW this is my gtx550ti:It already has a vga cooler on it doesn't it?
Don't forget about swapping the bottom one around to be an intake fan.
Yes. Your GTX 550ti already has a cooler, however there are plenty of aftermarket (better) options like The Great Randini was getting at.
Ask the community
