Not enough power getting to GPU? 560 ti
  • Graphics Cards
  • Power
  • Graphics
January 9, 2012 4:52:35 PM
Hey guys,
I need your opinions, How Do I know If My Graphics Card Is not getting enough power?
I ask this because I recently got a 560 ti and I'm using an OCZ stealthXstream 500w.
OCZ don't seem to be a bad brand. And Minimum requirements of 560 ti is 500w. and 30 amps 12v.
My psu is rated at 18 amps per 12 volt rail. ( I have 2) so technically that means I have 34 amps. So i should be fine...
What do you guys think?
Thanks,
Alec
Btw, nothing fancy in my case, 1 HDD, no optical drive.
More about : power gpu 560
a c 188 U Graphics card
January 9, 2012 4:55:39 PM
Is it running?
No crashes, image defects?
Than you're OK. Run a benchmark for a bit like 3DMark, should stress things enough that if you had issues you'd see them then.
a b U Graphics card
January 9, 2012 5:14:41 PM
500 Watts should be Plenty
Quote
Our test system is based on a power hungry Core i7 965 / X58 system. This setup is overclocked to 3.75 GHz. Next to that we have energy saving functions disabled for this motherboard and processor (to ensure consistent benchmark results). On average we are using roughly 50 to 100 Watts more than a standard PC due to higher CPU clock settings, water-cooling, additional cold cathode lights etc.
We'll be calculating the GPU power consumption here, not the total PC power consumption.
Measured power consumption
System in IDLE = 161W
System Wattage with GPU in FULL Stress = 329W
Difference (GPU load) = 168W
Add average IDLE wattage ~ 20W
Subjective obtained GPU power consumption = ~ 188 Watts
End Quote.
Concur with hang-the-9.
What I'd do is run furmark and monitor the +12V rail. Min val for +12 V rail is 11.4, but Myself I ditch the PSU if it drops below 11.6V. Side Note, there was one post here where the +12 was within spec, but the output was very noisy creating problems.
Bottom Line, NO problems, and +12 V is above 11.6 while running furmark, then GOOD to go!
January 9, 2012 5:35:09 PM
Quote
End Quote.
Thanks for both your replies. One last question, How do i measure 12v rail voltages? :)
Thanks for your help
a b U Graphics card
January 9, 2012 5:52:32 PM
Normally the best option is to check the Utility disk that comes with the MB. It normally has a section on "health" showing voltages and temps.
2nd choice is a software program such as CPUID HWMonitor (Can goole it for down load). If you try it and the +12 V shows up as 8 or 10 volt - ignore it as it is wrong, and has not been updated for your MB/CPU. Inwhich case there are some other programs such as Speedfan, ect.
