Hi all,
Quick dumb question. I have this mobo (http://www.newegg.com/Product/Product.aspx?Item=N82E16813186205) and was planning on getting this power supply (http://www.newegg.com/Product/Product.aspx?Item=N82E16817170015) for a build I'm putting together for my dad. I noticed that the mobo has a plug for the "8 pin CPU power connector", but when I look at the specs of the power supply, I don't see anything that corresponds with that (just that it is ATX, which is what I need). Will the power supply work with the motherboard, or do I need to find one that has a cable for the 8 pin CPU power adapter?
First build, sorry for the dumb question.
Thanks!
Thanks!
