Hi,
I have recentley installed a second EVGA GTX 460 SC EE 1GB 256-bit card into my rig
and everything seemed cool until my whole PC froze, I could see the desktop but everything was frozen.
I have no problems with the second card out like before, but it doesn't make sence since I have a
700W PSU.
Here are the stats for it...
-80 PLUS Bronze Certified
-4 + 12V output circuits
-Support Dual GPUs and Dual/Quad core CPUs
-APFC ATX12V Version 2.3 and EPS12V version 2.91 compatible
-1 x 6 pin and 1 x (6+2) pin Dual PCI-E ready
I had to connect 2 molex-to-6pin connectors to have an additional 2 x 6 pin for the second GPU
but I'm assuming thats ok to power it since the GPU came with the adapters.
I running a i7 870 NOT overclocked with Corsair H60 Liquid Cooler,
16 GB DDR3 Patriot 1333EL Series (High Performance Gaming RAM), 4 x 120mm LED Case Fans,
LG BD-ROM/DVD Rewriter Drive, a single SATA Drive, with a 27'' ViewSonic FULL HDMI Widescreen monitor.
I have checked extreme power calculator or whatever and it says i should only be using approx. 400+w
so I'm not sure whats going on?
The PSU is fine without the second card in as I have been using it flawlessley for about 3 months,
and the second GPU is fine also?
700W PSU.
