Will the i7-2600 work with my motherboard?
Last response: in CPUs
Short answer, No.
You have the previous generation socket, 1156.
The Intel CPUs are socket 1155 (and LGA2011).
You will have to replace your board to run any of the current Intel CPUs.
Related ressources
callebo said:
Oh man... I checked with a friend if it would, guess he (and I) was wrong...
Is there any motherboard you would recommend?
lol, don't worry, everyone makes mistakes :p
As for the a new motherboard, look at a motherboard with a Z77 chipset. That will future-proof your build (if Intel doesn't change from the 1155 socket for the next generation of CPUs)
Brand wise, can't go wrong with an ASUS, Gigabyte or MSI motherboard.
Ask the community
