Can I reuse the case, power supply, hard drive, cpu cooler, and dvd burner in my current build from summer of 2007 in my new gaming build? Even if I can reuse some of them can you tell me if it would be better to upgrade and buy something newer anyway?
Current build parts:
COOLER MASTER Stacker 830 Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119103
AeroCool ZERODBA S620 620W ATX12V / EPS12V SLI Certified CrossFire Ready Modular Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817331002
Western Digital RE2 WD5000YS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136032
LITE-ON Black 16X DVD-ROM 48X CD-ROM ATAPI/E-IDE DVD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106066
COOLER MASTER Hyper TX2 CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103031
New build:
- Mobo: undecided
- Core i7 2700k processor
- 1- Ati Radeon HD 7970 (plan to buy another later on for a crossfire setup)
- Mushkin Chronos Deluxe 240 GB (will be used as primary HDD, want to also install old drive mentioned above)
- CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
New build:
- Mobo: undecided
