Hello
This is my very first computer build, so please be gentle, i couldnt find any threads specific to the issue that i am having so here goes.
i built it specifically so i could play games on higher settings, so this is my first experience with computer parts in general.
after putting everthing together and connected correctly, my issue is that the computer will not stop rebooting. during windows installation it would restart almost at the very beginning everytime (barely making it past the windows starting up animation). A friend of mine was able to run windows on it through something called "system prep" (once again i'm a novice), and it would load windows for only a couple of minutes and then restart. since then i've tried installing windows on my own and its same old story, keeps rebooting during installation.
at first i thought it might be an issue with my power supply, but another friend of mine brought over one that was much better than the one i got and still same issue.
the cpu is not overheating, ive checked the temp in bios immediately after a reboot, and i've also felt around the cpu error and there's no heat to be at all concerned about.
at this point i'm thinking that i have some type of compatibility issue with my motherboard and cpu, the cpu is supposed to be compatible with my mobo according to asus, and the bios that comes stock with it is also supposed to be compatible according to amd (bios was also updated when my friend was able to get windows going). Ive seen that there can be a wattage issue between the mobo and cpu which may cause reboot, but i was unable to find anything specific to my hardware.
i'd really like to pinpoint what the issue is, its been almost a week and still no pc running, also i live in a small town and the computer store is about an hour away for me to return/exchange something, so i dont want to go all the way over there and have to go back again.
any help would be greatly appreciated...here is the list of hardware im running...
Case: NZXT Lexa S
CPU: AMD FX 6100
Motherboard: Asus M5A78L-M LX Plus
Video Card: EVGA GeForce GTX 550ti
Power Supply: Diablotek UL Series 575 Watt PSU
Hard Drive: Western Digital Caviar Blue 160 GB
CD/DVD Drive: MSI 24x DVDRW Drive
Memory: PNY MD8192KD3-1600-X9 XLR8 4GB x2
CPU Fan: Cooler Master Hyper 212 Plus
Case: NZXT Lexa S
CPU: AMD FX 6100
