I have a home built system, I think it'll help to list the specs
Motherboard: Asus Rampage III Extreme (was on offer)
CPU: i7 920 @ default clocks/voltages (I reset because was trying to find out why computer was experiencing issues)
GPU: GTX 570 @ default clocks/voltages (reason above)
RAM: 6 GB DDR3 Patriot Viper @ default clocks/voltages (reason above)
S. Card: Creative X-FI Titanium
So basically, the issues I experience are that:
■ Random shutdowns, irrelevant to computer usage. It has shutdown when gaming, youtubing, idling. Shutdowns used to happen about once a week, now it's almost daily, becoming increasingly frequent.
■ If I turn it on any time after a random shutdown (immediately to many days) the PC doesn't boot up fully. The fans don't spin up, the HDD light is always on and not flashing, the LED on the motherboard shows that it freezes on POST. My motherboard shows which part of the POST sequence the computer is at; on the usual CPU > DRAM > GPU > Boot Device sequence, the LED stays on CPU.
To get the PC up and running again after a random shutdown, I need to unplug and plug back in the 24 pin ATX plug. This will always work immediately after a random shutdown and any time after that. My computer has never recovered from a random shutdown without the re-plugging in of the 24 pin ATX plug.
I think the issue is the power supply.
How long are PSU warranties usually? I can probably request a replacement if they're no shorter than 2 years. I hope it's the PSU and not anything else.
Thanks
Thanks
