Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822136533
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) Built-in Speakers
http://www.newegg.com/Product/Prod [...] 6824236049
SAPPHIRE 11196-02-40G Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card (OC Version)
http://www.newegg.com/Product/Prod [...] 6814102963
LITE-ON Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model iHDS118-04 - OEM
http://www.newegg.com/Product/Prod [...] 6827106276
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Prod [...] 6817139021
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
http://www.newegg.com/Product/Prod [...] 6820145345
ASUS P8P67-M PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813131707
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Prod [...] 6819115072
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Prod [...] 6832116986
ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
http://www.newegg.com/Product/Prod [...] 6835118074
Rosewill RHRC-11001 Windows Vista/Window7 MCE Infrared Remote Control with Learning Function
http://www.newegg.com/Product/Comb [...] 11-352-015
Is this build good enough to play high end games at very high fps(1080p) also i want to play my xbox up to this monitor while having my computer still connected.
Any foreseeable problems/suggestion?
