So what case will be the best for air cooling. It will need to be big enough to fit an NH-d14 as well as the side panel fans.
Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139009
NZXT Phantom 410 CA-PH410-G1 Gunmetal Steel / Plastic ATX Mid Tower Black Trim Computer Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146093
NZXT SWITCH 810 Matte Black CA-SW810-M1 Steel / Plastic ATX HYBRID Full Tower Gaming Computer Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146095
NZXT Phantom PHAN-001BK Black Steel / Plastic Enthusiast ATX Full Tower Computer Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
If you think there are other better cases from other manufacturers, pls state them.
