I am building a new gaming computer, this will be my first tower build, and need some help determining if all the components go with each other, have a look:
CPU- Intel Core i5 2400 sandy bridge
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
Hard-Drive- WD 1TB Intellipower 6.0gb/s
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136942
*BOUGHT*GPU- Gigabyte GV-N460OC-1GI V3 GeForce GTX 460 (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125412
MOBO- GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502
DVD- LG 22X Super-Multi DVD Burner 22X DVD+R
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136240
Heatsink/Fan- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
*BOUGHT*Case- Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
*BOUGHT*Power Supply- OCZ ZS Series 750W 80PLUS Bronze High Performance Power Supply
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341049
*BOUGHT*Memory- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
If there are any discrepancies just let me know, I am trying to conform to what has already been bought, so if there is anything that doesn't match up, let me know how I can change the NON-BOUGHT items. Thanks for you're help :]
