K Kermheat Honorable Jun 27, 2012 22 0 10,510 Jul 1, 2012 #1 Why should I get a modular power supply? What's the benefits?
Solution dudewitbow Jul 1, 2012 the only advantage modular cables have is: 1. you don't have to mess with uneeded cables in the case 2. if a cable gets cut or damaged, modular cables are replaceable at a cost other than that, paying for modular is usually an optional expense.
dudewitbow Dignified Apr 11, 2012 4,868 1 15,460 Jul 1, 2012 Solution #2 the only advantage modular cables have is: 1. you don't have to mess with uneeded cables in the case 2. if a cable gets cut or damaged, modular cables are replaceable at a cost other than that, paying for modular is usually an optional expense. Upvote 0 Downvote Solution
K Kermheat Honorable Jun 27, 2012 22 0 10,510 Jul 1, 2012 #3 Best answer selected by Kermheat. Upvote 0 Downvote
