CHASSIS INTRUDED FATAL ERROR... SYSTEM HALTED
Hello,
My PC show an error in startup "chassis intruded fatal error system halted"
please solve this error why this message is show in startup
My MotherBoard is ASUS P5P800-MX
9 answers Last reply
More about chassis intruded fatal error system halted
  1. some boards/cases have a switch that is pressed when the door is on, when the door is off the switch opens and you get that error. If your case doesn't have this switch (or you don't care) you can turn it off in the BIOS
  2. WHEN I TRY TO GO TO SETUP, I GET THE SAME ERROR MESSAGE AND THE SYSTEM LOCKS ON THAT SCREEN.
  3. Please do not use all caps. Its considered to be rude.
    If you cannot get into the BIOS you will need to check the jumpers. You want a jumper on pins 1&2 on the CLRTC header and a jumper on pins 3&4 for the Chassis Intrusion header. If these are set correctly try resetting the BIOS and replacing the BIOS battery.
  4. Read your motherboard manual on this feature. It show you the relevent details (such as discussed above).
    Sorry about the all cap.
    What you just suggested, i've already tried and i still get the same error message along with new ones;
    CMOS Settings Wrong
    CMOS Date / Time Not Set
    New CPU Installed. Please Enter Setup To Configure Your System
    Chassis Intruded
    Fatal Error... System Halted
    (I don't know if this makes a difference, but i neglected to mention the fact that i don't have the cover to the chassis.)
  6. Sorry about the all cap.
    CMOS Settings Wrong
    Chassis Intruded
  7. Well there you probably are then. You need to trick that chassis switch into thinking there is a cover on again by taping the switch down.
    Try that and let us know. If it works, then go into the BIOS and turn off the Chassis intrusion.
    Also sounds like you have to re-enter all you PC data into the BIOS due to the CMOS reset.
    By the by, what happened to the cover?
  8. http://vip.asus.com/forum/view.aspx?id=20100910141859640&board_id=1&model=P5V800-MX&page=1&SLanguage=en-us
    Good luck. The forum above takes a while to load. Start with the simple "I just pull the power plug (after a safe shut down) and then held the power button for 15 seconds. Plugged power back in - and bam! booted up just fine. Sometimes the simplest tricks work. "
    When that fails try "chek the chassis intrusion jumper on ur mobo "see the manual user for your mobo before removing or changing the place of any jumper" a jumper most be placed on the ïn 2 and Pin 3 this is the right jumper position to desactivate the chassis intrusion option after that you should remove the CMOS battery and Clear the CMOS settings By placing the CRLTC jumper on pin 2 and pin 3 for almost 10 Secondes then place it again between pin 1 and pin 2 after that put the CMOS battery then start your pc and check if the problem persist again" Before doing this verify the pin positions against your MB manual.
    I don't have a cover or a chassis switch. They somehow got lost in the process of moving.
Prebuilt Asus Motherboards Systems
