Hello, and thanks in advance for all the help from the community!
I am planning my build of a new gaming desktop, some components I'm hard set on others I could care less about and that is why I am seeking advice from the community. Will all of these parts fit in the case? Are there better options I'm overlooking?
Things to consider
I plan on overclocking to 4.5ghz if possible as a constant
Budget isn't much of an issue just needs to stay under 3k.
I am perfectly aware of this being overkill.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
This can change to fit the needs of the system but the price point needs to stay around the same
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131802
I really like the upgrade-ability and space afforded by the extended ATX mobo and I also wish to use 2 16 gig quad channel kits for lower timings as opposed to one 32 gig kit. However if anyone can convince me that I wont notice the timing difference I'll be more than glad to consider advice on using a cheaper mobo and different ram kit(s)
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171063
open for other options but I thought 1300w would give plenty of headroom and its currently in a combo deal with the previously mentioned case
Graphics: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130785
planning for 2 of these in SLI since 680's and 690's are in a constant short supply. Open to other GTX 670 options if theres no need for the extra VRAM but only ONE will be installed due to budgeting at time of build
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233197
2 kits, but as I stated above if I can make it work with better sticks I'm all for it. Picked for low profile ease of build
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492
not open for discussion
Cooling: http://www.frozencpu.com/products/15140/ex-wat-203/XSPC_Raystorm_RX360_Extreme_Universal_CPU_Water_Cooling_Kit_w_RX360_Radiator_and_Free_Kill_Coil_Hot_item.html?id=8zRJWy3n
I really was looking for feedback on this choice especially as I am concerned about whether it will even fit
HDD will be SSD, open to suggestions!
Thanks again!
Things to consider
Thanks again!
