What would be the problem when cd does not read while other cd are read
Hi,
i have write some photos in a compact disk. when i tied opening in my pc the cd was not read. but earlier i have used the cd in laptop and opened to view the photos and also copied them. what is the problem? is it with the cd? kindly help me.
3 answers Last reply
More about what problem read read
  1. CD-ROM lens weakness, try to use a lens cleaner then try.
  2. Hi :)
    Try a BRANDED cd...NOT a cheap one.....if not its the drive...
    All the best Brett :)
  3. burnable cd's and dvd's degrade over time. Sunlight will degrade them much quicker otherwise you need to reburn them every few years unless you are using the more expensive archival quality disks and then its 50 to 100 years depending on the cd's/dvd's.
    on stamped disks, like music that you bought from the store, keeping the backside scratch free is much more important than the clear side. The clear side actually focuses the laser onto the reflective side so light scratches there don't have a huge impact. But a scratch on the reflective (label) side of the disk is like the grand canyon to the focused laser beam. I once had a customer engrave his name onto all his disc's on the label side and wonder why they no longer worked. :( poor guy.
CPUs Laptops CD-Rom
