Nitov2 Distinguished Apr 21, 2010 46 0 18,530 Jul 2, 2012 #1 Where do these cables plug in to? Are they to be plugged in to the motherboard, if so will they be labeled on the mobo?
Solution DJDeCiBeL Jul 2, 2012 Yes, into the motherboard. Something like this (although it may be slightly different) It should be labeled on the mobo, but the print will be small, so you might need to take a look at the manual, as well.
DJDeCiBeL Splendid Dec 3, 2010 6,060 1 27,965 Jul 2, 2012 Solution #2 Yes, into the motherboard. Something like this (although it may be slightly different) It should be labeled on the mobo, but the print will be small, so you might need to take a look at the manual, as well. Upvote 0 Downvote Solution
Nitov2 Distinguished Apr 21, 2010 46 0 18,530 Jul 2, 2012 #3 Best answer selected by Nitov2. Upvote 0 Downvote
Nitov2 Distinguished Apr 21, 2010 46 0 18,530 Jul 2, 2012 #4 DJDeCiBeL : Yes, into the motherboard. Something like this (although it may be slightly different) http://img.tomshardware.com/us/2002/09/18/building_your_own_pc/panel_leitungen.jpg It should be labeled on the mobo, but the print will be small, so you might need to take a look at the manual, as well. Thanks for the help. These cables scared me I did not know what to do with them up until now. Again thanks. Upvote 0 Downvote
