I've had my prebuilt Cyberpower desktop for a few years and this is a recent problem. Every time when I'm playing a game on my computer it will eventually just turn off with no warning and then after a minute or two will turn itself back on. I get the warning screen on bootup about not turning it off correctly so I'm pretty sure it's a hardware problem.
I've seen some other threads before that suggest this problem could be the PSU or the graphics card or overheating. I've already did major dusting and found I don't do that often enough.
Windows 7
MB: Gigabyte GA-P55A-UD4P
GPU: 2x Nvidia Geforce GTX 480
PSU: Coolermaster Pro 1250 RS-C50-EMBA-D2
CPU: i7 K875
I have 6 fans, 2 of which are used by the Enermax liquid cooler on the CPU. I can't be more specific because I can't find it on their website. A cylinder on the CPU has tubes to a block between two fans.
Oddly I get turned off more often on Star Trek Online than Mass Effect 3. When I turn my computer on there is no beep, that could mean a PSU problem but I read online that Gigabytes beep codes are for very broad reasons.
I've used SpeedFan to log my temperatures and voltages to try and figure this out myself. But I can't find any website to explain the chips sensors and which voltages are normal and which are not.
Here are my current Idles (ambient is 22C)
Chips:_____IT8720F____________LM75_ADT7473________________________________Intel core
GPU_GPU__Temp1_Temp2_Temp3_Temp_CPU___Local_Remote 2__CPU__Local__Remote 2_Core 0_Core 1_Core 2_Core 3
51.0_54.0__46.0__25.0___35.0___2.0___45.0__43.0__45.0 48.75_46.25_48.75_45.0 44.0_45.0___45.0___1.26___1.58
And here is right before a crash
88.0_82.0__60.0__25.0___51.0___2.0___82.75_68.25_83.0 76.25_68.0__76.25_62.0 58.0_57.0___56.0___1.25___1.58
In trying to find out what means what; Everest thinks Temp1 is my MB and Temp3 is my CPU. But HWMonitor thinks Temp1 is my PCH and Temp2 is my CPU. Nvidia says my cards are good to 105C. Intel says my CPU's Tcase is 72.7C. So which probe is the correct probe? the IT8720F doesn't show any danger numbers but the ADT7473 might mean I'm in trouble. Maybe my discontinued liquid cooler failed?
Now for my power numbers
Idle
IT8720F________________________________________|ADT7473
Vcore1_Vcore2_+3.3V_+5V__+12V_-12V_-5V__+5V_Vbat_|Vcore_+3.3V_Vcore_+3.3V
3.3____4.97___3.39__-1.09_-8.12_3.58_3.26__3.0_3.21_3.0___3.23
Crash
3.26___4.92___7.17__-1.58_-7.07_3.58_3.26__3.0_3.16_3.0___3.18
That +3.3V is freaking me out, it's got the largest jump and since I was in ME3 when I crashed I assumed it was for a graphics card, but I managed to find a website that explained what voltages are in what wires and the graphics cards don't get 3.3v, the MB and SATA (rarely used) do. http://www.playtool.com/pages/psuconnectors/connectors.html (Those last 2 empty columns are not a typo, SpeedFan gave me nothing for them.)
Windows 7
CPU: i7 K875
Idle
Crash
